Old 03-06-2010, 01:44 PM
BadInfluence's Avatar
BadInfluence BadInfluence is offline
Vehicle: 2006 Dodge Ram 1500 5.7
Color: Custom-mauhahaha
Rep:170
BadInfluence has a spectacular aura aboutBadInfluence has a spectacular aura about
Send a message via Yahoo to BadInfluence
Default Definition of 'ACCELERATION'
One top fuel dragster 500 cubic inch Hemi engine makes more horsepower than the first 4 rows of stock cars at the Daytona 500.
It takes just 15/100ths of a second for all 6,000+ horsepower of an NHRA Top Fuel dragster engine to reach the rear wheels.
Under full throttle, a dragster engine consumes 1-1/2 gallons of nitro methane per second; a fully loaded 747 consumes jet fuel at the same
rate with 25% less energy being produced.
A stock Dodge Hemi V8 engine cannot produce enough power to drive the dragster's supercharger.
With 3,000 CFM of air being rammed in by the supercharger on overdrive, the fuel mixture is compressed into a near-solid form before ignition.
Cylinders run on the verge of hydraulic lock at full throttle.
At the stoichiometric (stoichiometry: methodology and technology by which quantities of reactants and products in chemical reactions are determined) 1.7:1 air/fuel mixture of nitro methane, the flame front temperature measures 7,050 deg F.
Nitro methane burns yellow. The spectacular white flame seen above the stacks at night is raw burning hydrogen, dissociated from atmospheric water vapor by the searing exhaust gases.
Dual magnetos supply 44 amps to each spark plug. This is the output of an arc welder in each cylinder.
Spark plug electrodes are totally consumed during a pass. After halfway, the engine is dieseling from compression, plus the glow of exhaust valves at 1,400 deg F. The engine can only be shut down by cutting the fuel flow.
If spark momentarily fails early in the run, unburned nitro builds up in the affected cylinders and then explodes with sufficient force to blow cylinder heads off the block in pieces or split the block in half.
In order to exceed 300 mph in 4.5 seconds, dragsters must accelerate an average of over 4G's. In order to reach 200 mph (well before half-track), the launch acceleration approaches 8G's .
Dragsters reach over 300 miles per hour before you have completed reading this sentence
Top fuel engines turn approximately 540 revolutions from light to light! Including the burnout, the engine must only survive 900 revolutions under load .
The redline is actually quite high at 9,500 rpm.
Assuming all the equipment is paid off, the crew is working for free, and for once NOTHING BLOWS UP, each run costs an estimate $1,000.00 per second.
The current top fuel dragster elapsed time record is 4.428 seconds for the quarter mile (11/12/06, Tony Schumacher, at Pomona, CA). The top speed record is 336.15 mph as measured over the last 66' of the run (05/25/05 Tony Schumacher, at Hebron, OH).
Putting all of this into perspective: You are driving the average $140,000 Lingenfelter 'twin-turbo' powered Corvette Z06. Over a mile up the road, a top fuel dragster is staged and ready to launch down a quarter mile strip as you pass. You have the advantage of a flying start. You run the 'Vette hard up through the gears and blast across the starting line and pass the dragster at an honest 200 mph. The 'tree' goes green for both of you at that moment. The dragster launches and starts after you. You keep your foot down hard, but you hear an incredibly brutal whine that sears your eardrums and within 3 seconds, the dragster catches and passes you. He beats you to the finish line, a quarter mile away from where you just passed him. Think about it, from a standing start, the dragster had spotted you 200 mph and not only caught, but nearly blasted you off the road when he passed you within a mere 1,320 foot long race course.
... and that my friend, is ACCELERATION!
I bought it, I built it, I drive it.
Old 03-06-2010, 02:21 PM
Good stuff!!!
Old 03-06-2010, 02:22 PM
Excoastie's Avatar
Vehicle: 2016 Jeep Wrangler
Trim Level: Rubicon Hard Rock
Color: Hydro Blue
Rep:1358
AWESOME!!!!!!
Exco
Bill
Old 03-06-2010, 04:36 PM
hemiv8dodgeram1500's Avatar
Vehicle: Jeep GC WK
Rep:964
or you could ride in a toyota, sorry i had to say it
Old 03-06-2010, 04:41 PM
Thats living on the edge .
Old 03-06-2010, 05:08 PM
deanthecrabman's Avatar
deanthecrabman deanthecrabman is offline
Vehicle: 2001 Ram 1500 Quad 4WD 5.9
Trim Level: Quad cab
Color: Garnet red
Rep:202
deanthecrabman has a spectacular aura aboutdeanthecrabman has a spectacular aura aboutdeanthecrabman has a spectacular aura about
Was behind one once. Never got off the line. I was about 60ft behind and off to the left, holding my ears and feeling it in my chest. AWESOME!!
Old 03-06-2010, 05:16 PM
bones64's Avatar
bones64 bones64 is offline
Trim Level: slt/sport (bones)
Rep:659
Got to say SAAAAAAAAAAAAAAAAWEEEEEEEEET
Old 03-06-2010, 05:28 PM
Dann's Avatar
Dann Dann is offline
Vehicle: 1998 Dodge Ram
Trim Level: SLT sport
Color: red
Rep:183
Dann has a spectacular aura aboutDann has a spectacular aura about
Thats amazing am shocked
Old 03-06-2010, 06:08 PM
Big Daddy's Avatar
Big Daddy Big Daddy is offline
Vehicle: 2009 Crew Cab / 3.92 rear end
Trim Level: SLT Big Horn
Color: Stone White
Rep:917
Big Daddy is a splendid one to beholdBig Daddy is a splendid one to beholdBig Daddy is a splendid one to beholdBig Daddy is a splendid one to beholdBig Daddy is a splendid one to beholdBig Daddy is a splendid one to beholdBig Daddy is a splendid one to beholdBig Daddy is a splendid one to behold
That's awesome! I've never really been into drag racing as much as I've loved nimble handling road & rally cars but since I've gotten my truck I'm getting more and more into it. And the more I watch, the more respect and awe I feel for the people and machines that do it. Drag racing really is pure power. Thanks for sharing that!
Big Daddy
Marching to Mamasita's beat for a real real long time...
____________________
Dennis
Old 03-06-2010, 06:44 PM
Yondaime Yondaime is offline
Vehicle: 1997 Dodge Ram 1500 Sport 4x4
Color: Green
Rep:65
Yondaime will become famous soon enough
lol That is cool!!! I really make you think how much they put in to their machines.
