Old 03-06-2010, 06:35 PM
sd2500's Avatar
sd2500 sd2500 is offline
Vehicle: 2005 2500 RAM 4x4 Diesel
Trim Level: Cloth - all acc
Color: Maroon
Engine: 2005-???? 359ci (5.9L) Cummins ISB 610 24-Valve Diesel I6 325hp 610 lb/ft
sd2500 is on a distinguished road
Default Hid conversion
Anyone done a HID conversion kit on their RAM. My headlight housings have a metal dome covering the end of the bulb. I am wondering if I need to take these out for the HID bulbs because they get really-really hot!
I found a 55watt HID conversion kit for like $59 at DDM Tuning in San Diego. I put them on my Polaris RZR and WOW - is that a lot of light. So now the headlights in the RAM look like candles. I want to see when I am blasting through desert roads at night.
Old 03-06-2010, 06:39 PM
ScatPak07's Avatar
Rep:970
You should be fine since there are a lot of guys running them. You have to get the H13 bulbs which have the hi/low beam in one
Welcome to the forum by the way. Introduce yourself in the newbie section
Old 03-06-2010, 06:44 PM
No, you should be OK. That little reflector in there will be OK and needs to stay as it allows the light off the bulb to be reflected back into the housing, giving you a uniform light pattern.
I've got HID fogs in and am working my way through a small flickering issue with my HID kit for the headlights. But when they work, they are awesome!
You didn't post up what year your truck is. It would be a good idea to re-visit your User CP and edit your details to add the info on your truck and your location. It will help us help you when you have a question.
Welcome to the forum.
Old 03-06-2010, 07:28 PM
wermbang wermbang is offline
Trim Level: Sport- Off Road
Rep:1930
I just ordered a 35w 6000k set for my projectors from DDM a couple days ago. But will be awhile for them to shop out.
