Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > Dodge Ram Detailing and General Maintenance Forum > Rust Repair
Rust Repair Fighting Mother Nature!
Old 03-08-2010, 09:07 AM
03 Hemi's Avatar
03 Hemi 03 Hemi is offline
Vehicle: 2003 Dodge Ram
Color: Blue
Rep:13
03 Hemi is on a distinguished road
Default Rust Remover
Ok, I don't actually have a problem with rust. If you open my fuel door, the one screw that holds the fuel door on has begun to rust. I'm not so much concerned about the screw rusting as the stain left on my paint that leaked out of the fuel door. With all the snow we have had this winter, I didn't notice it until I washed my truck yesterday. There is about a 3" long stain on my paint from where the rusty water must of leaked out of the fuel door. What is the best to use to remove this without hurting the paint? Thank you.
Josh
2003 Dodge Ram 1500 QC, 5.7 Hemi
Old 03-08-2010, 09:09 AM
Wash the area.
Get out some light rubbing compound.
Lightly work the rubbing compound into the area with a wet microfiber cloth. Don't rub hard. Use a random circular motion.
Wipe off. Check for stains. Repeat if necessary.
When the stain is gone, wax and buff the area.
Old 03-08-2010, 10:21 AM
03 Hemi's Avatar
Color: Blue
Rep:13
Great, thanks Maddog!!!!
Josh
Old 03-08-2010, 10:30 AM
hemiv8dodgeram1500's Avatar
Vehicle: Jeep GC WK
Rep:964
i agree good job MADDOG
Old 03-09-2010, 04:58 PM
02BlackSLT 02BlackSLT is offline
Vehicle: 2002 Ram 1500
Trim Level: Quad Cab
Rep:28
02BlackSLT is on a distinguished road
You can use Meguairs Fine cut cleaner. It works well for this stuff. any paint stains for that matter.
Old 03-19-2010, 03:20 AM
Smitty's Avatar
Smitty Smitty is offline
Vehicle: 2009 Dodge Ram 1500 4 x 4
Smitty is on a distinguished road
Try a cleaner wax or pre-wax paint cleaner before applying any abrasive polishes like rubbing compounds. I would avoid using any rubbing compounds by hand unless you have a rotary buffer that you can use to correct the damage created by the abrasives in the polish. Understand that rubbing compounds remove small amounts of the clear coat.
Old 05-20-2010, 12:33 PM
hockeyplaya13's Avatar
hockeyplaya13 hockeyplaya13 is offline
Vehicle: 2002 1500 Quad Cab SLT
Color: Atlantic Blue
Rep:22
hockeyplaya13 is on a distinguished road
I'm kind of on board with Smitty. Try some sort of cleaner wax first, since the rust stain isn't below the the paint surface. You won't need to abrade the paint, just chemically remove the rust particles. If that doesn't work, I suppose the compounding would work. I'd just prefer to try to chemically remove it first.
Old 06-24-2010, 08:43 PM
three percent hero's Avatar
three percent hero three percent hero is offline
Rep:12
three percent hero is on a distinguished road
If you can get your hands on some detailing clay, that usually works great on rust, and it's much less abrasive than a rubbing compound. Just make sure you keep it lubricated with a surface gloss product (i.e. P&S Showroom Shine). And I always like to wash and wax after using clay as it can leave a little residue behind.
Old 06-24-2010, 09:32 PM
Rep:2616
take the screw out & replace it with a stainless screw, after you get rid of the stain
