Old 03-08-2010, 10:49 AM
kicknjeep kicknjeep is offline
Vehicle: 1995 Dodge Ram 1500
Rep:26
kicknjeep is on a distinguished road
Default Axle actuator!
I guess that's what you call it, But I need a write up on replacing the front axle actuator,Or at least a step by step on how to replace. Looks easy enough but taking no chance. Kudo thanks in advance......
Old 03-08-2010, 11:05 AM
blueflu blueflu is offline
Vehicle: 02 quad cab Ram, 94 Jeep YJ, 9
Color: cranberry
blueflu is on a distinguished road
It's called a CAD or Central Axel Disconect. Nothing hard to it.
You might check into a 4x4 Posi Lock though. Does away with the vac part and works great, alot of guys with Jeeps thta have the CAD swap to the Posi lock.
edit: Just saw you are right up the road from me.
Old 03-08-2010, 11:57 AM
Rep:26
hey Blu so it's kinda like the eliminator kit for the YJ axles, is there a site for the kit for my truck? Thanks. Yup good 'Ol Lebanon.
Old 03-08-2010, 12:06 PM
RamTech RamTech is online now
Rep:1885
VACUUM SHIFT MOTOR
REMOVE AND DISASSEMBLE
  1. Disconnect the vacuum and wiring connector from the shift housing.
  2. Remove indicator switch.
  3. Remove the shift motor housing cover, gasket and shield from the housing Shift Motor Housing
  4. Remove the E-clips from the shift motor housing and shaft. Remove shift motor and shift fork from the housing Shift Motor Components
  5. Remove the O-ring seal from the shift motor shaft.
  6. Clean and inspect all components. If any component is excessively worn or damaged, it should be replaced.
ASSEMBLY AND INSTALL
  1. Install a new O-ring seal on the shift motor shaft.
  2. Insert the shift motor shaft through the hole in the housing and shift fork. The shift fork offset should be toward the differential.
  3. Install the E-clips on the shift motor shaft and housing.
  4. Install the shift motor housing gasket and cover. Ensure the shift fork is correctly guided into the shift collar groove.
  5. Install the shift motor housing shield and attaching bolts. Tighten the bolts to 11 Nm (96 in. lbs.) torque.
  6. Add 148 ml (5 ounces) of API grade GL 5 hypoid gear lubricant to the shift motor housing. Add lubricant through indicator switch mounting hole.
  7. Install indicator switch, electrical connector and vacuum harness.
Old 03-08-2010, 12:56 PM
Color: cranberry
Yes same thing. If you use that then you can have 2wd low range.
Might give www.4wheelparts.com a shot or call the guys at the Nashville store.
I'm in Hermitage.
Old 03-08-2010, 01:10 PM
Rep:26
thanks Rem exactly what I was looking for just wasn't using the correct words in the search. Blu If you haven't yet you need to go play on the rock coarse at Tennessee Offroad, it's a blast.
