Gas Mileage - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > Dodge Ram Detailing and General Maintenance Forum > Fuel System
Fuel System All Fuel Discussions. MPG - Mileage - Fuel System Maintenance including Air Filter Replacement.
Old 03-01-2010, 04:26 PM
1BigHemi's Avatar
1BigHemi 1BigHemi is offline
Vehicle: 2006 Dodge Ram Mega Cab
1BigHemi is on a distinguished road
Default Gas Mileage
Hey Can anyone help me with gas mileage issues? I recently purchased a 2006 Ram 1500 Mega Cab Laramie, which previous owner had aftermarket 20" wheels put on it, I've re calibrated speedo, but am only getting about 9mpg. This just seems way off to me. I cam from driving a Silverado which when towing my trailer got better than this. Im not sure if it had its 30k tune-up, would that affect gas mileage to the tune of 3 to 4 mpg?(been told i should b getting around 12mpg). Any help would be appreciated....Keith
SUCKING GAS & GOING FAST-THE ONLY WAY TO GO!!
Old 03-01-2010, 04:30 PM
Rep:1625
I would definitely look into that tune-up. (air filter, spark plugs, maybe seafoam?)
Old 03-01-2010, 07:23 PM
Rep:1915
MADDOG says he's only getting 9 or so with his megacab 1500. I'm sure a tune up wouldn't hurt though.
Old 03-01-2010, 07:45 PM
Rep:1625
MADDOG has some pretty big tires on his, so his may differ slightly (assuming Keith's tires aren't as big as MADDOG's)
Old 03-01-2010, 09:46 PM
1BigHemi's Avatar
My Tires are 305/50/20 nitto grapplers if that makes any difference, what about the pcv valve? does that need to be changed with the tune up too?
Old 03-01-2010, 09:49 PM
1BigHemi's Avatar
What is seafoam?
Old 03-01-2010, 09:53 PM
Rep:1625
Check out this thread: http://www.ramforumz.com/showthread.php?t=46518
It helps clear out a lot of built-up gunk.
Old 03-01-2010, 09:54 PM
kasrx7000 kasrx7000 is offline
Vehicle: 05 ram 2500
kasrx7000 is on a distinguished road
sea foam is like a fuel injector cleaner you can get it at any autozone . as for the fuel milage im gettin between 12 and 13 and i have an 05 2500 with a 115000. miles on it. i just changed the pcv and cleaned the throttle body seems to help some
Old 03-01-2010, 09:58 PM
ScatPak07's Avatar
Rep:970
Well that does seem like a low MPG. I am getting aroun 12MPG in my quad cab. I have 305/55/20 tires on my truck. I also took my MDS off which stops the 4cylinder switch over.
A tune-up never hurts!
Old 03-01-2010, 10:07 PM
1BigHemi's Avatar
Im sitting at 49500k not sure if previous owner did the 30k tuneup so I may start there, and try the seafoam as well, does anyone have a particular spark plug in mind that works better than the cheap mopar champions?
