Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > 4.7L PowerTech V8 Specific Topics
Old 03-16-2010, 11:57 PM
coolidge coolidge is offline
Vehicle: 2014 Ram 1500 CC 5.7L 3.92
Trim Level: Big Horn CC 6'4" box
Color: Maximum Steel
Rep:16
coolidge is on a distinguished road
Originally Posted by HoustonHemi View Post
Heads do not 'go bad' / lose compression all at once while the engine is idling.
Timing chain?
Did they have MDS in 04?
If reworking the heads 'fixes' this, I'll be very suprised,,,,
What does "reworking the heads" even mean? Valve guides come on I don't see that. Surface the heads? If he blew a head gasket it would be puking water or oil and again seems unlikely at idle. MDS system maybe but the lifters are are in the block.
I would be demanding to see any parts replaced, this smells like something that's been in the fridge too long.
Old 03-17-2010, 04:00 AM
deanthecrabman's Avatar
deanthecrabman deanthecrabman is offline
Vehicle: 2001 Ram 1500 Quad 4WD 5.9
Trim Level: Quad cab
Color: Garnet red
Rep:202
deanthecrabman has a spectacular aura aboutdeanthecrabman has a spectacular aura aboutdeanthecrabman has a spectacular aura about
I'd be curious to see if the heads were actually off. Good way to buy time.
Old 03-17-2010, 07:23 PM
chefred112's Avatar
Vehicle: 2005 Dodge Ram
Rep:656
sub'd..this has peaked my curiousity.....cam position sensor? but again, no codes so i could see how they are shootin in the dark..
Old 03-18-2010, 11:45 PM
TerryXn9's Avatar
TerryXn9 TerryXn9 is offline
Vehicle: 2010 RAM
Trim Level: Crew Cab Sport
Rep:31
TerryXn9 is on a distinguished road
My Dads 2002 Dakota has the 4.7 in it and it was idiling rough. It would die as soon as he let go of the gas. We took it to the dealership and they couldn't find it. So i figured i'd check out the throtle body. Come to find out it was the IAC Valve (Idle Air Control). It has tons of carbon and gunk build up on it. I changed it and now it runs top notch. So maybe thats worth a shot?
2010 Crew Cab Sport! With a HEMI
Old 03-19-2010, 11:32 AM
Kens04's Avatar
Kens04 Kens04 is offline
Vehicle: 2004 Ram QC 4x4 HEMI
Trim Level: SLT OFF ROAD
Rep:48
Kens04 is on a distinguished road
No MDS in 04. I like the IAC valve theory, somewhat cheap in price and easy to replace. Not a mechanic so some of the other theorys I cant comment on. Good luck and let us know what happens.
Old 03-20-2010, 01:07 PM
04ram4X4's Avatar
04ram4X4 04ram4X4 is offline
Trim Level: Off Road Package, ST
Color: Blue
04ram4X4 is on a distinguished road
Send a message via Yahoo to 04ram4X4
Ok went to the dealer and the heads are off. There is also a collapsed valve spring!!!!!! Maybe chrysler was right? It will be finished Wednesday we shall see. Oh and the throttle body has been spit shined.
Old 03-20-2010, 05:35 PM
Color: Garnet red
Rep:202
Good to hear they got it figured out.
Old 03-21-2010, 03:56 AM
Incognito's Avatar
Incognito Incognito is offline
Vehicle: 2003 Dodge Ram 1500 Crew Cab
Trim Level: 5.7L Hemi 4x4
Color: Graphite Gray
Rep:72
Incognito will become famous soon enough
Originally Posted by 04ram4X4 View Post
I miss my truck so BAD!!!!!!!!
So do I. I miss just getting out of the house...
Originally Posted by Toms Blue Ram 1500 View Post
Sounds like their taking a swing in the dark and with the blind folds on also . Never heard of heads having to come off because it won't idle .
I agree. I actually call that dealership bulls**t. 'Cause back when I was at GM we would never remove the cylinder heads of a vehicle just for the problem that you described. That's a load of money to charge a customer to rip off the cylinder heads of an engine just 'cause it isn't idling right.
Old 03-21-2010, 12:40 PM
HoustonHemi's Avatar
HoustonHemi HoustonHemi is offline
Vehicle: 1492 Santa Maria
Color: Hot pink
Engine: 1981-1987 225ci (3.7L) Slant-6 95hp
Rep:135
HoustonHemi will become famous soon enoughHoustonHemi will become famous soon enough
Intake, I assume????
Old 03-27-2010, 01:34 PM
04ram4X4's Avatar
Color: Blue
Got my truck back yesterday and it's fixxed!!!!!!!!!!! The valve spring did it. Just wanted to let you know.
