Old 03-15-2010, 10:22 PM
CHVYKLR's Avatar
CHVYKLR CHVYKLR is offline
Vehicle: 2009 Ram Crew 2WD
Trim Level: Lone Star
Rep:252
Originally Posted by MotorCityRam View Post
Definitely not good w/ 1 5/8" at that power level. They might work but are far from proper. I would bet money you'd pick up power w/ a 1.75" primary header on that setup.
I could pick up a little more PEAK hp but at my boost/power level the low and mid rpm gains with the 1 5/8 JBA longtubes outweigh the small PEAK gains of a 1 3/4. My car is built for the street and I spend 99% of the time below 6k rpm anyway.
Like others my choice was not only based on results but also money. A good set of 1 3/4 longtubes are only made by a few companys for my application (Kooks, ARH) and cost almost double. Trust me, I wanted to go with something better than ceramic coated JBAs 1 5/8s. But after the research, a 5-10 peak hp increase for about another $700 just wasn't worth it.
Old 03-16-2010, 06:55 AM
MotorCityRam's Avatar
MotorCityRam MotorCityRam is offline
Vehicle: 2010 Ram QC 4x2
Color: Inferno Red
Rep:23
MotorCityRam is on a distinguished road
Where's your peak tq? 1 5/8" headers aren't even really adequate for these truck's 4k peak tq reading. I'd bet there's more than 10hp in a 490whp setup.
Sean M
2010 Quad Cap Sport 4x2 / Inferno Red / HEMI / 3.92s / leather / Truxedo Truxsport tonneau
Old 03-16-2010, 08:50 AM
CHVYKLR's Avatar
Rep:252
My peak Q is about 5300 rpm. My hp never stops climbing and was only limited by redline. I don't want to continue to hijack this thread so if you want to see all my research, graphs, and links to articles PM me and I'll fwd it. From what I found the JBAs don't become a restriction until somewhere in the high 500s (rwhp).
Just rechecked and at was a 13 hp gain at my boost level. I will def agree with you that the gains would continue to grow as boost is increased and the power level goes up.
Old 03-16-2010, 09:53 AM
Color: Inferno Red
Rep:23
If ScatPak07 is interested I thought the info sort of directly applied since it most of it points to what could or couldn't be a good choice design-wise. I'd love to see your data (HUGE tech-freak motorhead. ) Otherwise I'll drop out after this post and can move to PM.
The generally accepted formula for required area of the primary tube, based on an ideal 240fps exhaust velocity, is:
(Peak Tq RPM/88200)/CID of one cylinder
For a 16ga header OD you'd put that area into this: (SQRT of ((4 * Primary area)/ PI )) + 0.12
18ga header would be: (SQRT of ((4 * Primary area)/ PI )) + 0.098
Gets tricky w/ a blower though as you're sort of artificially increasing displacement and it tends toward the larger of what would be indicated. Undersize the primary diameter and you'll pull the tq peak down a bit (and likely limit power too). Go oversized and you can bump the tq peak a bit. Longtubes will swing the tq cureve bell about the peak, boosting the lower end's numbers at the expense of the top end. Shorties will do the opposite.
Just GENERAL guidelines as cam, intake runner length, gearing, etc all has an effect as well. For the trucks, if you really just want to boost power for towing, low rpm use, a slightly undersized longtube header. If you're looking to boost the truck's overall acceleration, a larger primary tube is what you want to look at, possibly considering a shortie. Here you'd definitely want to be running decent gears to get you up into the rpm's a bit quicker.
My old carbed 300+rwhp 302 combo really wanted a 1.75" header based on the 4500rpm tq peak w/ the 1.625 shorties it had. A cam swap on one of these HEMI's and you're moving the tq peak over the stock 4000rpm which already is just barely over the 1.625" point.
Another point to consider is that, at the 4th gen hp levels, by the math the single pipe portion of the exhaust should probably be closer to 3.5", or move to true 2.5" dual.
Sean M
Old 03-16-2010, 10:02 AM
CHVYKLR's Avatar
Rep:252
I gotcha. He prob could use some of the info. Another reason I choose the 1 5/8 was that many (not all) of the 1 3/4 headers dumped into 3" collectors vice the 2.5" H-pipe and Borla Stingers that I currently have. I didn't want to have to replace my entire exhaust based off of a header install. I would have had $2k+ into an exhaust! haha.
Old 03-16-2010, 10:28 AM
Color: Inferno Red
Rep:23
I hear ya. And on the blower car there's a point of diminishing returns w/ the increase in power. Probably already melts tires.
Sean M
Old 03-16-2010, 08:10 PM
ScatPak07's Avatar
Rep:970
Well guys thank you so much for all the help!!!
I have made the decision to get the Dynatech headers. They seam to be the best long tube headers out there. They are the highest quality ones so I would like to go with them.
I appreciate all the help guys, you guys are awesome aha!!!!
Old 03-16-2010, 08:11 PM
CHVYKLR's Avatar
Rep:252
Here's the dyno run. Over 300 lb/ft at 1600 rpm.
I don't know how to post pics so here is a link to the dyno sheet.
http://s647.photobucket.com/albums/u...o.jpg&newest=1
Old 03-16-2010, 08:33 PM
Color: Inferno Red
Rep:23
Last hijack...
Wow...that thing just keeps pullin'. Shoulda kept your foot in it.
Sean M
Old 03-16-2010, 10:34 PM
CHVYKLR's Avatar
Rep:252
Scat, that's awesome. Are you doing the install? If so, maybe post some pics of the process and a couple of lessons learned for the rest of us. I really want to do a set myself so I'm anxious to hear.
