Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - News Desk > Newbie Checkin!
Newbie Checkin! New to the forums? Introduce yourself here!
tonneaucovered.com
Old 03-14-2010, 04:14 PM
cumminsnothummin cumminsnothummin is offline
Vehicle: 04 ram 2500 cummins
Trim Level: laramie
Engine: 2004-2004 359ci (5.9L) Cummins ISB 600 24-Valve Diesel I6 325hp 600lb/ft (6-Speed Manual)
cumminsnothummin is on a distinguished road
Lightbulb Cummins down
hELP!! MY 2004 2500 CUMMINS JUST STOPPED HUMMIN. aT THE SAME TIME THE FUEL GAGE, CRUISE ,VOLTMETER, AND FUEL PUMP STOPPED RESPONDING. CAN ANYONE POINT ME TOWARD THE LIGHT AT THE END OF THE TUNNEL??
Old 03-14-2010, 04:28 PM
This sounds like a primary electrical problem. Will it turn over or is it totally dead?
First, check all fuses.
Then, check your battery + & - connections at all 4 ends. Make sure your cables are in good shape and there's no grease or foreign material on the connections. Good time to clean them.
Then, check your computer main harness plug in. Normally these don't come loose but it's good to check.
Old 03-14-2010, 05:09 PM
BlueJet BlueJet is offline
Vehicle: Blue
Rep:3934
Hello and welcome!
Glad you joined us, sorry it is under these conditions. As you see, we have many helpful people here, I hope we can help you solve your problem!
Enjoy the board!
Old 03-14-2010, 07:42 PM
Glad you joined us and welcome to the Z for Rams from Baltimore . If you could go to the top of the page to the User Cp and complete your profile that would be great . Helps us see what you have when your posting a question . Are the batteries dead ? Will the motor crank over ? You will find this site is full of a lot of talented people . So if theres any question that you need answered , just shoot away . Talk to ya soon . Tom
Old 03-14-2010, 08:53 PM
Resident Technician
Rep:1911
Might start by checking the ignition switch outputs and B+ inputs.
Old 03-14-2010, 08:55 PM
Rep:4110
Hello and welcome to RamForumZ, great to have you here, just sorry to hear about your trouble, and unfortunately, I'm not much help, but looks like you're getting some good advice already, so good luck in getting it resolved and back on the road again! Be sure and keep us posted, and if you need any other help, feel free to ask, and if you complete your profile info in your User CP, it will help others answer your questions! I hope you enjoy the board!
Old 03-14-2010, 09:01 PM
I push the skinny pedal
Rep:3308
Welcome to the Z! There's been some good suggestions above. I'd also check the TPCM, this may have blown. Have you done any electrical work to the truck that could cause a surge or grounding?
Kurtis
Old 03-14-2010, 09:19 PM
ScatPak07's Avatar
Rep:970
Hello and welcome to the forum! Glad to have youaboard! Well I would have to agree with everyone else and say something is wrong with the electrical. I would suggest cleaning like Maddog had mentioned.
Best of luck man!! Hope she starts working again!
Old 03-14-2010, 09:23 PM
iRESQu iRESQu is offline
Rep:2217
Welcome aboard the Forumz. I am sorry you're having the problem with the Cummins. I too have a Cummins 6.7, but I haven't had too much difficulty with her. Wish you the best!
Old 03-14-2010, 10:00 PM
Trim Level: laramie
ok so my truck does turn over and most everyting still works all fuses have been checked fuse links batteries are fully charged and all connections are clean i even went as far as to remove the viper allarm and car starter so annyways obd2 computer cannot connect to the truck check engin light stays on and doesnt turn off or even flash voltmeter and fuelguage indicate empty once keyis on the square around the p for park disapears
