Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - General Discussion > Dodge Ram Special Edition Models > Dodge Ram Daytona
Old 02-01-2011, 05:37 PM
D.Rowe's Avatar
D.Rowe D.Rowe is offline
Vehicle: 2005 Dodge Ram 1500 Daytona
Trim Level: Daytona
Rep:121
D.Rowe will become famous soon enoughD.Rowe will become famous soon enough
Default Just Hit 60K miles...Proactive Maintenance Suggestions?
So I've had my daytona for a month now and love it more everyday. Cannot wait for some warmer weather here in CT so I can do some mods.
Flipped 60K yesterday and was thinking about any proactive maintenance that I can do..as in..replace something that isn't necessarily an issue yet but it's a good idea...thoughts?
Things that come to mind...
- spark plugs
- battery
- air filters
I a total rookie under the hood so any comments are welcomed here. I don't mind spending money to be proactive with items that make sense.
Thanks in advance.
Weather Tech mats, 12" Billet Antenna, Recon 60" LED bar, Spyder LED tailights, Map & Dome LED's, Pioneer AVH-P6300BT, Upgraded Tweeters in Dash, Cadence 8" Sub under Drivers Seat
Old 02-01-2011, 05:46 PM
MADDOG MADDOG is offline
Rep:22
Change engine oil.
Rotate tires.
check spare for proper pressure.
Flush and replace engine coolant
Drain and refill transfer case (4x4)
Change rear axle fluid
Change front axle fluid (4x4)
Inspect brake linings
Replace air filter
Replace spark plugs
Inspect ignition cables
Inspect PCV Valve, replace as necessary
Drain and refill automatic transmission fluid, change main sump filter.
Inspect front accessory drive belt, replace as necessary.
Old 02-01-2011, 05:48 PM
D.Rowe's Avatar
Trim Level: Daytona
Rep:121
Change engine oil.
Rotate tires.
Replace air filter
Replace spark plugs
Great list...thanks much MADDOG!
Old 02-01-2011, 05:57 PM
Rep:22
Glad to help out!
Old 02-06-2011, 09:44 PM
Dalton's Avatar
Dalton Dalton is offline
Vehicle: 2005 Dodge Ram Daytona
Trim Level: Daytona
Rep:43
Dalton is on a distinguished road
The EGR valve gave me issues at about 125k i think on the same truck. From what i read quite a few other people too. That might be something to look into.
Old 02-08-2011, 07:29 PM
D.Rowe's Avatar
Trim Level: Daytona
Rep:121
Will do....but what is the EGR valve?
Old 02-11-2011, 07:43 PM
Dalton's Avatar
Trim Level: Daytona
Rep:43
exhaust gas recirculation i believe
Switch back l.e.d's platinuminjected Custom Dodge Ram Interior and Exterior Lighting 21 02-26-2013 12:59 AM
interior lights in 98 ram 1500 lacamu Custom Dodge Ram Interior and Exterior Lighting 6 08-12-2011 02:43 PM
General Maintenance at 50,000 miles JBSPartans05 Dodge Ram Detailing and General Maintenance Forum 0 08-15-2010 11:39 AM
98sst has many miles. 98sst Dodge Ram General Discussion 20 05-09-2010 11:30 AM
How many miles before changing to syn? imnxnyr Dodge Ram General Discussion 9 12-01-2009 06:51 AM
