Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > Cummins Diesel Specific Topics
tonneaucovered.com
Old 07-04-2010, 04:51 PM
racer57 racer57 is offline
racer57 is on a distinguished road
Default changing vacuum pump
Can someone tell me what is involved in changing the vacuum pump on my diesel. Is this a gear to gear connection and is there a timing thing with the gears? What else is to this.
Old 07-04-2010, 05:02 PM
I'm not sure . Let me check the shop manual and I'll get back to ya .
Old 07-04-2010, 05:18 PM
I'm unable to find anything on vacuum pump replacement . Wheres it located ?
Old 07-04-2010, 08:56 PM
power steering pump bolts to it and it is under the injecter pump
Old 07-04-2010, 10:10 PM
I just went through the fuel system , brake system , diesel engine section , steering section , then did a search . I couldn't find anything and the search came back with nothing . Sorry I tried . And that was with the factory shop manual .
Old 07-05-2010, 02:37 AM
lil bit lil bit is offline
Vehicle: 1999 Dodge Ram 2500
lil bit is on a distinguished road
my manual reads "pull the vacuum pump & power steering pump to the rear to disengage the vacuum pump drive gear from the timing gear". Hope that helps?
Old 07-05-2010, 03:20 AM
strang3majik's Avatar
strang3majik strang3majik is offline
Vehicle: 1996 Dodge Ram Indy Pace Truck
Trim Level: Indy Pace Truck
Color: Blue w/ white stripes
Rep:210
strang3majik has a spectacular aura aboutstrang3majik has a spectacular aura aboutstrang3majik has a spectacular aura about
The vaccum pump may be the power steering pump. A lot of older turbo cars were run that way...I believe Grand Nationals were...for instance.
Not sure about turbo diesels...but maybe that'll help your search?
98 Jeep Grand Cherokee 5.9 Limited / 96 Dodge Ram Indy Pace Truck / 87 Dodge Charger GLHS / 85 Dodge Omni GLH
