Rear Diff fluid ?? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 03-16-2010, 04:39 PM
trainplanemech's Avatar
trainplanemech trainplanemech is offline
Vehicle: 1998 Dodge Ram
trainplanemech is on a distinguished road
Default Rear Diff fluid ??
Im sure its been here a hundred times, so pardon me, I suck at finding even simple things with the search function.
My question is what is recomended for the rear diff on a fluid change buy the majority of you all here.I have a 98 2 wheel 318, and the rear end was new in OCT, I bought the truck a month ago.I have noticed the rear diff seal is seaping some fluid and wanna take care of it this week at work.Most likely be doing the water pump to while Im in a fixin mood,its starting to sqeek all the time.
Thanks in advance.
Old 03-16-2010, 07:43 PM
Zekery360 Zekery360 is offline
Vehicle: 2002 Dodge Ram
Color: Bright Red
Zekery360 is on a distinguished road
If you mean good fluid to use, I only use Mopar fluids in my truck (for the most part). If you can spend tons of money, I hear many good things about Royal Purple.
Old 03-16-2010, 10:35 PM
Thanks in advance.
Might want to try and spray the fan belt first and see if the noise stops for a bit . Don't hear water pumps make a squeeking sound . They will get a bearing growling type sound .
Old 03-17-2010, 01:03 AM
Yea when I went to pick up a rear diff gasket today the sqeek was gone.Good for now I guess.
My question I meant should u stick with the fluid given in the manual.Manual are iffy at times.
Old 04-03-2010, 07:34 AM
Got it all done a week o rso ago.I can see what it was leaking.No gasket and barely had any cheap black rtv for a seal....good job Aamco..lol.Wow suprises me at the work some of these placed do and the prices they charge folks.
Old 04-03-2010, 09:29 AM
strang3majik's Avatar
strang3majik strang3majik is offline
Vehicle: 1996 Dodge Ram Indy Pace Truck
Trim Level: Indy Pace Truck
Color: Blue w/ white stripes
Rep:210
strang3majik has a spectacular aura aboutstrang3majik has a spectacular aura aboutstrang3majik has a spectacular aura about
if you have a limited slip (posi) differential. Make sure to add the limited slip additive. Without it, it won't last long.
98 Jeep Grand Cherokee 5.9 Limited / 96 Dodge Ram Indy Pace Truck / 87 Dodge Charger GLHS / 85 Dodge Omni GLH
