Old 03-17-2010, 11:35 PM
deathproof deathproof is offline
Gender: Not Specified
deathproof is on a distinguished road
Default Where's the coolant temp switch??
I have a 2004 5.7 Ram, where's the coolant temp switch?
Thanks
Old 03-17-2010, 11:54 PM
The coolant sensor on the 5.7L is located under the air conditioning compressor, installed on a water jacket at the front of the engine.
There's a document attached with some pics and directions for removing it.
Old 03-18-2010, 12:56 AM
I upgraded my radiator and the new wiring harness says to connect it there.
I assume I should just splice in the (-) fan switch control there. That's what the instructions say. I also assume that's what tells the fans when to kick on?
Thanks
Old 03-18-2010, 01:14 AM
Yup, you got it.
Old 03-18-2010, 01:32 AM
I also have a wire that is for the AC Clutch.... any idea of what that is and what it should connect to?
BTW: I have this engine in my street rod, that's why all the guess work.
