Cummins down - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - Dodge Cummins Diesel
Custom Dodge Ram Performance Mods - Engine - Dodge Cummins Diesel Discuss modifying your Dodge Ram with Performance Parts and Accessories!
Old 03-18-2010, 01:52 AM
cumminsnothummin cumminsnothummin is offline
Vehicle: 04 ram 2500 cummins
Trim Level: laramie
Engine: 2004-2004 359ci (5.9L) Cummins ISB 600 24-Valve Diesel I6 325hp 600lb/ft (6-Speed Manual)
cumminsnothummin is on a distinguished road
Angry Cummins down
so i need some help my 04 quad cab cummins broke down i have no fuel pump no voltmeter and no fuel guage obd 2 code reader cant connectto computer truck turns over i checked all grounds and fuses allis good i had a viper alarm but took it out after it broke and still no go. i asked the last 2 owners and they dont know the story on this truck since befor them it came from a dealer in florida where it already had an intake 4inch exhaust pods for turbo boost pyrometer and trans temp as well boost was put up to 40 psi so im thinking that the truck has been chipped but i did not find any form of piggy back so im tinking a programmer? could this cause a problem after a year and a half on top of it all i cant find wiring diagams any where can any one help
Old 03-20-2010, 08:18 PM
MegaRamMan MegaRamMan is offline
Vehicle: 2006 Dodge Ram 3500
Trim Level: Laramie Mega Cab
Engine: 2005-???? 359ci (5.9L) Cummins ISB 610 24-Valve Diesel I6 325hp 610 lb/ft
MegaRamMan is on a distinguished road
Default Hey Sounds Like a Lift Pump
On 20003 5.9l the lift pump use to go. They ended up putting it in the fuel tank on later models.
"If you wanna make steam you gotta burn some coal"
Jason
Old 04-03-2010, 12:45 PM
pokeyjoe pokeyjoe is offline
Vehicle: 2003
Color: BLACK
pokeyjoe is on a distinguished road
I had this problem and it was the lift pump. Give it a SMALL shot of starting fluid into the air intake. If it starts then you are not getting any fuel. I would give that a try. I had my system redone by a diesel shop. BAD NEWS........$700.00
Stephen Duncan 2003 Dodge Ram 3500
5.9 Cummins Turbo Diesel
Old 04-04-2010, 10:55 PM
dieselextreme dieselextreme is offline
dieselextreme is on a distinguished road
if your lift pump is out you can get one for around 150.00 and replace it in 2 hours
Old 05-19-2010, 07:57 AM
jsgood jsgood is offline
Vehicle: 2004 Dodge Ram 2500 4X4
jsgood is on a distinguished road
I put a FASS lift pump in myself. Mounted to the frame. Had to drop the tank to get the pickup line in, but it was no problem. Haven't had any trouble since then. The FASS is a little noisy, but I do not run out of fuel.
