steering locked help - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > 5.7L V8 Specific Topics
Old 03-18-2010, 02:56 PM
warwickram's Avatar
warwickram warwickram is offline
Vehicle: 16 ram megacab 2500
Trim Level: limited
Rep:38
warwickram is on a distinguished road
Default steering locked help
tried to start my 07 ram today the key wont turn and the steering is locked . when i parked it the tires were turned all the way to the left. it finally started but the steering is still locked any ideas my next step is to open up the colunm what should i look for. i really need some advice i am stuck thanks tom
Old 03-18-2010, 05:50 PM
Rep:2954
i could only find this & i think the guy didn't type well, words are mixed a bit
very commonly when you shut the engine off if the wheels are turned if you'll get pressure back against the steering column lock in this will jam the lock cylinder. It's very important to make sure the steering wheel is in a neutral position when you shut the key off because when he gets jammed you could easily break something more seriously.
Read more: http://www.justanswer.com/questions/...#ixzz0iZERqQyH
Old 04-07-2010, 06:33 PM
BlackdOut BlackdOut is offline
BlackdOut is on a distinguished road
I had almost the same problem. My steering wheel was locked and the key wouldnt turn. I had the turn the wheel back the same time I was starting my truck and it finally came loose. You might have broken a pin that holds the steering wheel.
Old 04-07-2010, 07:29 PM
bones64's Avatar
bones64 bones64 is offline
Trim Level: slt/sport (bones)
Rep:659
Man................Im just guessing. Have you tried to pull up or down the shift lever to see if it will move a touch? Then try and turn the truck on.I have had that prob. before not on a Ram but it did work.Good luck
Old 01-01-2011, 03:28 PM
marwes marwes is offline
Vehicle: 2003 Dodge Ram 2500 4X4 Cummin
marwes is on a distinguished road
I have the same problem and all of these solutions wont work. It's a 2003 Dodge Ram 2500.
Old 01-01-2011, 03:31 PM
Take the pressure off the steering wheel by grasping it firmly and turn it in the opposite direction of the way the front wheels are pointing. You are binding the locking pawl on the steering gear lock.
Old 01-01-2011, 03:51 PM
My wheels were straight to start with and I turned it left then right and it eventually locked worse in the far right position. I still can't get the key to turn.
