Old 03-19-2010, 04:14 AM
skar90 skar90 is offline
skar90 is on a distinguished road
Default 2wd suspension question?
i am a noob.
Simply out of curiosity i read that you can put the:
- 2007 ram 2500/3500 2wd shocks
ON A
-2007 ram 1500 2wd giving it a stock 2" lift?
anyone know anything about this or ever try it?
on another forum a member said he was running these:
Bilstien F4-BE5-C603-HO with his stock isolater in.
like i said any info is greatly appreciated. thanks!!
Old 03-20-2010, 09:26 PM
LSxFBODYgen3's Avatar
LSxFBODYgen3 LSxFBODYgen3 is offline
Vehicle: 2006 Dodge Ram
Trim Level: 1500 SLT
LSxFBODYgen3 is on a distinguished road
Correct me if im wrong but, shocks don't raise or lower a truck, only help dampen the movement. Springs will raise or lower the truck though.
The reason they put new shocks on lifted trucks is due to needing a longer shock (because of the longer range it now needs to move) and also better performance from internal valving.
If im wrong by all means let me know. Cause if that's the case Ill go buy a set of shocks for my 2wd and level kit and call it a day.
Old 03-20-2010, 10:06 PM
I push the skinny pedal
Rep:3277
Putting shocks on alone won't change the stance, you'd have to swap the springs as well since they are what actually takes the weight of the body, the shock is just a dampener to stop the spring from bouncing all the time.
I don't know about the number, but bilstein makes good shocks and they have some coil-overs that can be used to lift up to 2"
Kurtis
