2004 Dodge 2500 intermittent defrost issue - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Heating & Cooling
Old 03-19-2010, 12:40 PM
r1buden r1buden is offline
Vehicle: 2004 Dodge Ram
Trim Level: 2500 Off-Road
Color: Charcoal Grey
r1buden is on a distinguished road
Default 2004 Dodge 2500 intermittent defrost issue
I have a 2004 Dodge Ram 2500. I have a defrost issue..90% of the time when the dial is set on defrost it blows out the dash vents. , if you mess with it enough it will eventuallly start blowing from the defrost vents. If you leave the knob on defrost it will blow properly for serveral days, then you start the truck it blows out the dash vents again while still on defrost. I have read posts about a broken door but if that was my case I would think it would never change to the defrost vents...any ideas?
Old 03-19-2010, 08:53 PM
Resident Technician
Rep:1915
Yup, you most likely have broken mode doors. You're thinking old school but the new Rams don't use that type of setup.
Old 03-20-2010, 10:30 AM
bigredram bigredram is offline
Vehicle: 2003 2500 4x4 hemi
Color: poppy red
bigredram is on a distinguished road
i'm having the same issues, but in my case i dont think its the door itself, i think its the foam rubber seal the foam has come off but the sticky backing is still there, causing the door to stick. i havent taken anything apart to look at it but pieces of foam rubber keep coming out of my vents, which lead me to this "wild a** semieducated conclusion" good luck and "pass a great day"
