Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Towing
Towing 3rd Gen Dodge Ram Towing Questions
tonneaucovered.com
Old 07-22-2010, 06:25 AM
akt akt is offline
Vehicle: 2012 RAM 1500
akt is on a distinguished road
Hay guys I pull a 23ft Fun Finder camper that the stickers says it weighs around 3800 . My 07 laramie 1500 seems to struggle. Does a programmer really make a difference.
Old 08-01-2010, 10:01 PM
wskyzen wskyzen is offline
Vehicle: 2004 dodge ram 1500 4x4
Trim Level: st
Color: mineral grey
wskyzen is on a distinguished road
Originally Posted by 5speedram View Post
I've got an '03 Ram 1500 with the 4.7, 3.92 gears and a 5 speed. The recommended max tow weight is 5400. The recommended max GCWR is 10,500. If this truck had an automatic tranny the max tow weight would be 7350 with a GCWR of 12,500. Are these weights firm or is there any wiggle room? I'm surprised the manual tows so much less than the auto. I don't want to pull as much as the auto will handle but I may go over my limits by a small amount. Would there be a problem? What would bend/break first? The clutch? The gears in the tranny? Any info would be appreciated.
The thing is if your stopped while towing the sticker on your door is what the the cops and dot go by, and that is a hefty fine + they won't let you pull it any further. I spoke with a Dodge engineer once and he told me the main reason for the different tow ratings between transmissions is that 98% of the people that have man trans don't know how to drive them, especially when towing. He said the clutch will give out because people tend to slip it to much when towing instead of just getting off of it as soon as possible. I still wouldn't tow over the rating unless it's close to home and not very far.
Old 08-01-2010, 10:51 PM
Trim Level: st
Color: mineral grey
Originally Posted by ram2487 View Post
now here's a question for some mega cab 1500 owners...what tow rating do you trust more, the 1500 or the 2500 since it's built on the HD frame and has the same suspension and brake system as the 2500's?
Look in the owners man for your truck, a 1500 mega cab, find your gear ratio on the sticker on your door or on the diff. and it will tell you what you can tow.
Old 08-15-2010, 05:05 PM
slimeyslim slimeyslim is offline
slimeyslim is on a distinguished road
I have a 2005 Dodge Ram 1500. Truck gives me no problems, except that my tow package doesn't work when my headlights are on. All tow lights work fine when lights are off. Any help would be great. Thanks
Old 08-21-2010, 12:31 PM
drill35 drill35 is offline
drill35 is on a distinguished road
Default Trailor towing
I have a 2006 1500 4.7 with 3.92 rear I pull and travel trailor the only problem I have had is when pulling big mountains the torqe make the seal on the rear end leak a little gear oil. Does anyone else have this problem?
