Old 03-20-2010, 11:37 AM
welshdog welshdog is offline
Vehicle: 2005 Dodge Ram 1500
welshdog is on a distinguished road
Default Elusive EGR valve.....
Hi everybody! Please does anybody know how to locate the EGR valve on a 2005 Ram 1500 4.7? I am searching for it to replace a faulty one,but it is difficult to locate. A precise location spot would really help me.I would be soooo grateful for a quick reply to my problem.! Thanks and have a good day.
Old 03-20-2010, 04:37 PM
deanthecrabman's Avatar
deanthecrabman deanthecrabman is offline
Vehicle: 2001 Ram 1500 Quad 4WD 5.9
Trim Level: Quad cab
Color: Garnet red
Rep:202
deanthecrabman has a spectacular aura aboutdeanthecrabman has a spectacular aura aboutdeanthecrabman has a spectacular aura about
Checked Autozone's site, they have a component locater. Unfortunately, they have no data on your truck. Sorry.
Old 03-21-2010, 09:52 AM
Hi Dean,
appreciate you trying to help me,thank you. Have the new part,so will have to get back under there and keep looking. At least I know now what it looks like.
Sincerely, Rob Tate
Old 03-21-2010, 11:02 AM
Here ya go right from my Dodge shop manual for the 4.7 .
Removal .
4.7L
The electronic EGR valve and solenoid assembly (4)
is attached to the rear of the left cylinder head. An
exhaust gas routing tube (3) connects the EGR valve
to the intake manifold.
1. Remove electrical connector (5) at top of EGR
valve solenoid.
2. Remove tube mounting bolt (1) at intake manifold.
3. Remove two bolts (4) connecting EGR tube (1) to
valve assembly.
4. Remove gasket located between EGR tube flange
and EGR valve assembly.
5. Remove two EGR valve mounting bolts (5).
6. Separate valve assembly (3) from engine.
7. Remove and discard metal gasket located
INSTALLATION
4.7L
1. Clean area at rear of left cylinder head where it
joins base of EGR valve.
2. Clean EGR tube where it joins EGR valve.
3. Position new gasket between EGR valve and cylinder
head.
4. Position EGR valve to cylinder head. Install and
tighten two bolts (5) to 20 ft.lbs. (27 Nm).
5. Position new gasket between EGR tube flange and
EGR valve assembly.
6. Position EGR tube (1) to side of EGR valve and
into intake manifold. Install two bolts (4) finger tight
(temporarily).
DR EXHAUST GAS RECIRCULATION 25 - 55
7. Install EGR tube flange bolt (1) at intake manifold.
Tighten bolt to 20 ft.lbs. (27 Nm).
8. Connect electrical connector (5) to top of EGR
valve solenoid (2).
9. Do a final tightening of two EGR tube bolts (4) to
20 ft.lbs. (27 Nm).
Old 03-21-2010, 12:31 PM
Hi Tom,
thank you so much for that info. I located the EGR valve,however, I cannot see a way to get at it either from under the hood,or from below! It has to be in the most inaccessible spot ever! If you have ever replaced one,I would be grateful to know if there is a way to access it sucessfully. I really do not want to get into stripping down lots of stuff as I am not skilled at that sort of thing. I could see maybe that at a dealership or garage it would be easier up on a hydraulic lift,where you could stand underneath the vehicle,but I do not have access to that facility. I know it's a simple task basically,it's just getting at the damn thing!Again,thank you kindly,and if you know a way..........Sincerely, Rob Tate
Old 03-21-2010, 12:44 PM
Default EGR Valve......Again!! Help badly needed.
Hi everybody, posted a question yesterday about locating the EGR valve on a 2005 Ram 1500 4.7. Had replies,and found location of valve. However it is in a really hard place to get at,and I have no idea how to go about reaching it. I can hardly see it,tucked way back on the block on the drivers side. If anyone has ever changed one of these themselves, I would be very grateful for any tips on doing it! Thanks.....Rob Tate.
Old 03-21-2010, 04:50 PM
Default Can somebody help me???
Hi there,
I want to replace the EGR valve on my 2005 Ram 1500 4.7. I know where it is now (thanks to advice on this forum). I just don't see a way to get to it. If anybody has done this job themselves,would you mind explaining the way to do it. I have the new part.....I just want to fit it!!!! Thanks,in anticipation.
Old 03-21-2010, 04:57 PM
dodgeman70592's Avatar
Vehicle: 2008 Dodge Ram
Trim Level: Custom
Rep:1648
Well, not sure if its in the same spot as mine, seeing mine is a 5.7. You should see a metal tube that comes from the intake, follow it, it terminates at the EGR. Also be sure to take off and clean the tube as well w/ some brakeclean. You may want to send remerson228 and he could possibly provide you with a diagram w/ a service tech how to.
Old 03-21-2010, 05:25 PM
Thanks a lot.....will contact remerson228, I am grateful for any help with this!
Old 03-21-2010, 06:13 PM
I've never replaced one myself . But that is the procedure from the factory shop manual .
