Old 03-20-2010, 07:05 PM
FFEric06 FFEric06 is offline
Gender: Not Specified
FFEric06 is on a distinguished road
Default Changed the oil pan, now it Knocks HELP!!
Guys and Gals, I just changed the oil pan on my 1999 Ram 2500 4x4 with a 5.9 Magnum. I got the oil pan from advanced Auto, part # CRP19A. i start the truck up and it now knocks. kinda like a stuck lifter. I really need help here guys. Thanks a lot. Did i need to reprime the oil pump after i put the new one on? thanks for looking
Old 03-25-2010, 12:36 AM
GC99RAM GC99RAM is offline
Vehicle: 1999 Dodge Ram Quad Cab 4x4
GC99RAM is on a distinguished road
Yes, always prime the oil pump before you start your engine for the first time after replacing the oil pump. They make a tool that you can put in an electric drill that will fit where the distributor shaft attaches. All you do then is run the drill for about a minute and that gives the oil pump time enough to prime before you start the engine for the first time.
Old 03-25-2010, 01:13 AM
Rep:2620
I may be completely wrong, but buy the very best oil filter that is available for your truck
Old 03-25-2010, 03:06 AM
08 SRT8 3560's Avatar
08 SRT8 3560 08 SRT8 3560 is offline
Vehicle: 2010 Super Challenger #10 011
Trim Level: Mr Norm's SC'd 6.1l
Rep:786
08 SRT8 3560 is a splendid one to behold08 SRT8 3560 is a splendid one to behold08 SRT8 3560 is a splendid one to behold08 SRT8 3560 is a splendid one to behold08 SRT8 3560 is a splendid one to behold08 SRT8 3560 is a splendid one to behold08 SRT8 3560 is a splendid one to behold
Did you replace the pump or just the pan? if you did not replace the pump then it shouldn't have needed priming (no different than changing your oil) so the knock would be somethng else. this may be a little out there but what is the possibility your crank is making contact with either your new pan (possible baffles) or your pump itself (may have been turned from original position during pan install)
Mr Norms liquid cooled 2.8l Kenne Bell with 8lb pulley, Eibach coil over suspension, Hotchkis sway bars, Super Challenger Katzkin interior, Hurst short throw shifter. ARH longtube headers with high flow catted mid pipes, magnaflow cat-back exhaust. Black Viper style wheels with red raceline.
