Question about my spare tire - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 03-21-2010, 04:57 PM
YoMoma's Avatar
YoMoma YoMoma is offline
Vehicle: 2001 Dodge Ram 1500 4x4
Trim Level: Laramie SLT
Color: Green
Rep:18
YoMoma is on a distinguished road
Default Question about my spare tire
Hello, had a flat tire yesterday and had to put on the spare. The rim doesnt match the other 3 so I want to get another tire for the correct rim soon.
But for now I am using a P265/75R16 for the spare. The other 3 tires are P265/70R17.
The "fresh" spare tire is approx 30 1/2 inches tall while the other rear tire is 31 inches tall.
The spare replaced the driver side rear tire. But will using the slightly smaller sized spare tire hurt the rear end with 2 different sized tires being used? Or because it is limited slip it will be ok?
I plan on buying another tire to replace the spare in a week or two.
Old 03-21-2010, 05:10 PM
Rep:2929
i can't see it hurting anything as long as its on the rear for a while, but, it don't think that i would run it on the front for more than a weekend, but, if Chrysler thought it would be a problem, they would NOT have put that size rim & tire for a spare
Old 03-21-2010, 05:46 PM
bones64's Avatar
bones64 bones64 is offline
Trim Level: slt/sport (bones)
Rep:659
I dont see much of a problem either..as long as its in the rear. I wouldnt have it in the front. ?????????????Steering, front end components thats all.Just my 2 cents.
Old 03-21-2010, 06:58 PM
deanthecrabman's Avatar
deanthecrabman deanthecrabman is offline
Vehicle: 2001 Ram 1500 Quad 4WD 5.9
Trim Level: Quad cab
Color: Garnet red
Rep:202
deanthecrabman has a spectacular aura aboutdeanthecrabman has a spectacular aura aboutdeanthecrabman has a spectacular aura about
Are you sure that's what Chrysler put on it, or was it a leftover from a previous owner?
Old 03-21-2010, 08:35 PM
YoMoma's Avatar
Color: Green
Rep:18
I cant say for sure, but there was a small sticker on the sidewall that said something to the effect of "dealer installed air pressure" on the tire.
I did not buy the truck new though.
Old 03-21-2010, 08:37 PM
ScatPak07's Avatar
Rep:970
I do not think that it will hurt it if it is on for a temporary amount of time. You should be good! I would just keep that tire man, you will only use it a few days at a time if you get a flat. I still have my same spare tire and I have 33" tires haha
Old 04-07-2010, 10:31 AM
Ttsnelson Ttsnelson is offline
Engine: 2005-???? 359ci (5.9L) Cummins ISB 610 24-Valve Diesel I6 325hp 610 lb/ft
Ttsnelson is on a distinguished road
If you are worried about just swap it to the front not the back because you do not want your rear tires spining at different speeds that is what will screw up your rear end I have 33s on and my spare is stock so if I get a flat on the back I have to put the spare on the front and move a front back
Old 04-07-2010, 01:43 PM
Ruffian11's Avatar
Ruffian11 Ruffian11 is offline
Vehicle: 2005 Dodge Ram 1500
Rep:140
Ruffian11 will become famous soon enoughRuffian11 will become famous soon enough
if it is temporary it should hurt the vehicle at all....just dont drive it hard or anything and you should be good
2005 SLT 1500 5.7L Hemi
5" Rough Country Lift, Procomp 8101 20x9 Rims, K&N CAI,Flowmaster Exhaust Cat-Back Dual Exit, 325/60/20 BFG KM2, Tonneau Cover, Bedlined, Grill Hella 500's!
Alpine CDA-9887 Headunit, Twister 300 Amp, Dual 10" MTX Thunders, Thunder Form Box
