Old 03-21-2010, 08:54 PM
baldman 79 baldman 79 is offline
baldman 79 is on a distinguished road
Cool Reading check engine light codes
can any tell me how to read my check engine light codes my truck is a 1996 1500 4x4 i turn the key three times and get 1 blink followed by 2,2,2,5,5 would someone lplease explain this to me. i just recently swapped my 5.2 engine and trans with 235,000 miles still running fine for a 2000 5.9 liter engine and trans didnt change the computer used all sensors fuel rail and throttle body off my 5.2 . I had to change all the trans solenoids to match my computer trans works fine. The truck runs pretty good it feels like something is holding it back. when i start the truck cold on a warm day or not it misfires and runs like crap for about 5 minute then it runs fine. plz enlighten me someone,thanks
Old 03-21-2010, 11:59 PM
deanthecrabman's Avatar
deanthecrabman deanthecrabman is offline
Vehicle: 2001 Ram 1500 Quad 4WD 5.9
Trim Level: Quad cab
Color: Garnet red
Rep:202
deanthecrabman has a spectacular aura aboutdeanthecrabman has a spectacular aura aboutdeanthecrabman has a spectacular aura about
Sounds like you have an OBDI computer. Thought they did away with those in 95. If it is a 95 computer, those codes are 2 digit.
12-Battery input to PCM disconnected during last 50 key starts.
22-Coolant temperature sensor circuit.
55-Completion of fault code display.
Don't know enough about the engine swap, but this will bump it to keep it alive.
Good luck.
Old 03-22-2010, 11:28 AM
thanks i wonder why its running so crappy when cold maybe the computer needs flashed for a 5.9 ? none of the codes that its throwing would cause it to run rough would they?
Old 03-22-2010, 11:43 AM
Rep:1909
The code for the ECT sensor could because the PCM isn't seeing the correct engine temp.
Old 03-23-2010, 03:48 AM
could i put a different t stat in it maybe. that wouldnt make it run crappy at first start would it?
Old 03-23-2010, 09:03 AM
Rep:1909
A stat isn't going to change what the PCM is seeing if the CTS is bad and, no, a cold engine is a cold engine regardless of what stat is in it. You need to have the CTS code properly diagnosed.
