Old 03-22-2010, 09:38 AM
Robb Robb is offline
Vehicle: 1997 Dodge Ram 4x4 1500
Robb is on a distinguished road
Exclamation 1997 1500 4x4 5.9L Loss of Power
Hi, I have a 1997 Dodge pickup, and just recently I have had a major loss of power. It takes forever to get up to 50 mph, and stays around 2k-3k rpm unless I let off of the gas, then it will finally shift, but still be very doggy. I can tromp the gas and it will sound like i'm moving but it's barely climbing in speed.
It also has a hissing type sound like a vacuum leak or something while trying to climb in speed, but I can't tell where it is coming from because it doesn't do it when parked. About a week ago I had a mechanic shop replace my Water Pump, Thermostat, and Belt Tensioner, and now I have this problem.
Also, I have no warning, or check engine lights on.
(I made sure all spark plug wires were fastened.)
Any ideas would help a lot.
Old 03-22-2010, 09:40 AM
iRESQu iRESQu is offline
Rep:2217
Welcome Rob and glad to have you.
Unfortunately I don't have the knowledge to asist you but if you stick around, someone with more insight will chime in.
Old 03-22-2010, 09:42 AM
Thanks, ya hopefully someone can help me get this problem solved.
Old 03-22-2010, 10:56 AM
wermbang wermbang is offline
Trim Level: Sport- Off Road
Rep:1930
I do not have an answer for you either, but would suspect what the shop did, or maybe nicked a vacuum line somewhere???
Anyway welcome to the site. If you take a few moments and re-visit your User CP and edit your details to add the information on your truck and your location. That will help us help you when you have a question or are having a problem with your truck for future posts.
There are a lot of talented people on this site, so if you have questions feel free to ask, and I am sure someone will be able to help. If your looking for some accessories check out our vendor section and may the modding continue or begin
http://www.ramforumz.com/forumdisplay.php?f=53
Old 03-22-2010, 11:50 AM
Rep:1885
Sounds like more than a simple small vacuum leak to me. I'd get it checked for any stored codes.
Old 08-15-2011, 03:01 PM
96Ram25005.9l 96Ram25005.9l is offline
Vehicle: 1996 Dodge Ram
Trim Level: laramie SLT
96Ram25005.9l is on a distinguished road
Default check vacuum lines
check all of them i had a dry rotted vacuum line going to the TB it made my baby run like ish let me know
