AC Problems - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - Dodge Cummins Diesel
Custom Dodge Ram Performance Mods - Engine - Dodge Cummins Diesel Discuss modifying your Dodge Ram with Performance Parts and Accessories!
Old 03-22-2010, 01:40 PM
99BIGREDDODGE 99BIGREDDODGE is offline
Vehicle: 1999 DODGE RAM 2500
Color: RED
Engine: 1999-2000 359ci (5.9L) Cummins ISB 24-Valve Diesel I6 235hp 460lb/ft (manual)
99BIGREDDODGE is on a distinguished road
Default AC Problems
i am having problems with my ac system. it will blow cold air for about 10-15 min and then the air gets warm and wet. i blew out the drain in the firewall and is still doing it. the refrigerant is still goad and no leaks. anyone have any ideas?? dont want to take it to a ac shop$$$$$$. 99 dodge ram 4x4 deisel
Old 03-22-2010, 02:22 PM
Resident Technician
Rep:1915
What are your high and low side pressures and at what ambient temp with the system off and on?
Old 06-11-2010, 04:35 PM
Color: RED
not exactly sure what my pressures are, but it works longer on low humidity days and also my pass side floorboard is getting wet. and its not antifreeze. i think the drain may be stopping up but not sure....and not sure how to get inside to do it.
Old 06-11-2010, 06:24 PM
Resident Technician
Rep:1915
Your evaparator is probably freezing up. I'll have to check to be sure but I think theres a temp probe in the evap fins that's supposed to shut off the compressor to prevent this.
