Old 03-22-2010, 10:51 PM
BLACK07 BLACK07 is offline
Vehicle: 2007 Dodge Ram
Trim Level: SLT (QC/SB)
Rep:36
BLACK07 is on a distinguished road
Default Future plans and a few questions.
Ok, yes I am still rolling with just a rear flip kit and stock front haha.
my future plans are:
3" drop coils up front
most likely a c-notch (even though something about cutting my frame makes me queasy)
and then some air assist bags out back.
My questions are, does anyone have a rear bag kit with a flip kit and a c-notch? and was the install more complicated because of it? All of the air kits I have found are for stock trucks and they bolt on the frame (around the area of the bump stop... which will be totally different with the c-notch) and the top of the leaf spring (which is where my axle is now nicely nestled)
2007 Black Dodge Ram SLT QC/SB
DIY is the way to go!
Old 03-22-2010, 11:31 PM
I push the skinny pedal
Rep:3277
You'd have to make a custom brace for the lower bag mount, but the upper from a kit should be fine. Having a 'bag over a flip is quite common in dropped trucks, and going anywhere lover than a ~4" flip would require a notch, which isn't so bad if you box the frame and weld some filler plate in OR buy a good C-notch kit. If you want to go low and use bags, then a custom 3- or 4-link will give you the best variation in height and a 'bag system will move your level to where you want it.
Kurtis
Old 03-23-2010, 08:00 AM
bones64's Avatar
bones64 bones64 is offline
Trim Level: slt/sport (bones)
Rep:659
I have a 5 inch rear flip and i didnt have to notch the frame. Iam bottoming out but its the stock shocks. I have on order 2 inch lowering coils and new shocks all way around.Hoping it will look good.
Old 03-27-2010, 02:51 AM
chefred112's Avatar
chefred112 chefred112 is online now
Vehicle: 2005 Dodge Ram
Rep:656
I have a flip kit..used stock shackles to get a 6" drop, have a C notch, and also use slamair bag assists (top mounts to side of frame, bottom sits on leaf)
Old 03-27-2010, 03:10 AM
chefred112's Avatar
Rep:656
my current look..I forgot to take some air out of bags, she does sit a little lower..
