Old 03-24-2010, 09:39 PM
GregInAtl's Avatar
GregInAtl GregInAtl is offline
Vehicle: 2012 Ram 1500 QC
Color: Dk cherry red
Rep:130
GregInAtl will become famous soon enoughGregInAtl will become famous soon enough
Originally Posted by sowardcustoms View Post
Thanks guys Greg for now i'm doing the manual fill when I need it I have the compressor,tank, and valves the problem is getting the time to do it. I'm also working on the 50 GMC thats in the background it needs a little more attn.. but I plan on mounting the tank,compressor, and valves behind the front bumper maybe build a rack that has a mount on each end and bolt it in where the tow hook bolts would go if I had any that way it would make it easier to service and I figure with the valves close to the radiator in the winter time they would'nt be prone to freezing up....
I mounted everything to the driver side frame rails on mine, easy access, out of the way and sturdy mounting.
12 Ram express QC, belltech 963sp and McGaughys spindles, debadged,Polk audio, smoked lights, tint, bedcover, and lots more
06 Stratos 201 Pro XL 225 Yamaha
Old 03-24-2010, 10:35 PM
I push the skinny pedal
Rep:3277
I've been contemplating where I could mount mine as well since I'm in a very cold prone area and the last thing I'd want is frozen valves. I like your idea of mounting it by the rad for warmth, another option is near the muffler, they give of quite a bit if heat.
Kurtis
Old 03-24-2010, 10:37 PM
ScatPak07's Avatar
Rep:970
That looks really good man! Congrats on such a well done job!
Old 03-25-2010, 10:14 PM
GregInAtl's Avatar
Rep:130
If you keep moisture out, freezing is not much of an issue....that and move to Atlanta, where a freeze is an annual event for 2 days, not a one time event for 6 months!
Old 03-26-2010, 10:36 AM
sowardcustoms's Avatar
sowardcustoms sowardcustoms is offline
Vehicle: 2013 Ram R/T
Trim Level: R/T
Color: Gray
Rep:145
sowardcustoms will become famous soon enoughsowardcustoms will become famous soon enough
I've seen they make heated valves now I guess alot of people have the same problem....
Old 03-27-2010, 03:40 AM
chefred112's Avatar
Vehicle: 2005 Dodge Ram
Rep:656
..lookin good...the newer gen trucks look great lowered!
Old 03-29-2010, 08:23 PM
09 RT RAM's Avatar
09 RT RAM 09 RT RAM is offline
Rep:39
09 RT RAM is on a distinguished road
Talking
More pics..
Excellent! Thanks for posting the pics! Truck sits rightly sick. pm coming....
Old 03-31-2010, 12:51 AM
dustin72's Avatar
dustin72 dustin72 is offline
Vehicle: 2013 Dodge Ram1500 4x4
Rep:48
dustin72 is on a distinguished road
I want to do the same thing on my 2010 RCSB 4x4. I want to lower the rear about 1.5" and have the ability to pull a trailer with no sagging. What brand/part number did you use for the rear bags? Was it a simple R&R of the factory springs?
Black SRT10 22's with 305/45/22 Nitto NT420S Tires, 6000k Low and Fog HID's, Debadged, Tint, Custom Mopar Badges, S&B Intake, Magnaflow Muffler, Superchips Tuner
Old 04-01-2010, 07:57 PM
Trim Level: R/T
Color: Gray
Rep:145
There Airlift Dominator D2500 bags I ordered from suicidedoors I also used there bag plates 2 upper and 4 lower the extra ones for the lower plate where for the top of the factory spring mount so I would have something to bolt the top of the bag mount to and then measured and cut some tubing welded them to the plates and used all thread for the studs after all that yes it was pretty simple to swap the springs the factory springs will almost fall out if you jack the truck up all the way in the back.....
Old 04-02-2010, 12:01 AM
bodog1's Avatar
bodog1 bodog1 is offline
Vehicle: 2007 Dodge Ram
Color: Bright Silver Metalic
Rep:46
bodog1 is on a distinguished road
Truck looks awesome! I love the way lowered regular cab trucks look
07 Ram 1500 ST regular cab, 4.7, 2.5" Pro Comp leveling kit, Flowmaster exhuast
