Old 03-23-2010, 08:36 AM
TOPPERST TOPPERST is offline
Vehicle: 2004 DODGE RAM
TOPPERST is on a distinguished road
Default Question for "CAM" change.
Hi I am new to this forum. I am planning on changing the cam in a 2004 5.7 Ram. May go with the Comp Cam EX 268. Can anyone tell me if the computer can be reprogramed properly with a downloader such as a Predator or a Bully Dog. Or should I take it to a dyno shop? From what I been told, the new cam will cause a decrease in vacume pressure. Thanks for any help!
Old 03-23-2010, 09:35 AM
Rep:1845
I'm sure the cam will change the vacuum which will be seen by the PCM and alter the fuel delivery. What does Comp have to say about reprogramming for this particular cam grind?
Old 03-23-2010, 10:20 AM
I called Comp Cam tech support and was on hold for a 1/2 hour. When I got to talk to a tech, he did not give me any good answers.
Old 03-23-2010, 10:29 AM
Rep:1845
The big question is how much of a change from the factory cam will this one be? if the difference is mild, you may not need any serious changes to your PCM's programming. What are the specs on this cam?
Old 03-23-2010, 11:41 AM
Hi, thanks for your reply. I just went to a local speed shop that dose dyno. They said dont change the cam, the factory cam was well desinged. Other mods would be better. I guess that will save me $600.00, Thanks again!
Old 03-23-2010, 10:24 PM
MotorCityRam's Avatar
MotorCityRam MotorCityRam is offline
Vehicle: 2010 Ram QC 4x2
Color: Inferno Red
Rep:23
MotorCityRam is on a distinguished road
Bad answer IMO. Find another shop. The tough thing is these are speed density systems. Cam swap is pretty much going to guarantee you're going to need some tuning (at least anything that makes a worthwhile gain). There's some big hp to unlock in these motors w/ a decent sized cam but you're going to HAVE to tune for it.
That or gut the EFI and drop a carb on the thing and tune it in the garage.
Sean M
2010 Quad Cap Sport 4x2 / Inferno Red / HEMI / 3.92s / leather / Truxedo Truxsport tonneau
