Old 03-23-2010, 11:01 AM
rustyolred's Avatar
rustyolred rustyolred is offline
Vehicle: 1997 Ram 1500 ext cab 4x4
Trim Level: Laramie SLT
Rep:20
rustyolred is on a distinguished road
Send a message via AIM to rustyolred
Default Water pump leak?
Is it possible for the water pump to leak somewhere beside the weep hole? I am having an intermittent water leak and can't see to find it. Truck is NOT running hot when the leak occurs either. Anywhere else that I should be looking?
Rusty
Old 03-23-2010, 11:38 AM
Rep:1909
Are you seeing coolant on the ground or is it just disappearing over time? My first recommendation would be to have the cooling system and cap pressure tested.
Old 03-23-2010, 11:52 AM
rustyolred's Avatar
Rep:20
Getting it every once in a while on the ground. Also the water appears to be coming from near the A/C comp area. Is teh water pump weep hole on a 5.9 on the bottom? Where exactly?
Rusty
Old 03-23-2010, 12:03 PM
Rep:1909
It's on the bottom but the pulley may obscure your view. A pressure test will help pinpoint the source.
Old 03-24-2010, 12:58 AM
rustyolred's Avatar
Rep:20
The water pump was bad. Water was seeping out the weep hole and getting slung up to the top of the engine by the pulley. Now if I can just figureout how to wire the electric fan.
Rusty
Old 03-24-2010, 01:04 AM
OneShortOf OneShortOf is offline
Vehicle: 06 R/C sport, 05 Power Wagon
Trim Level: All of them!
Color: All black
Rep:38
OneShortOf is on a distinguished road
Rusty
Post up what your working with and the parts you have im sure we can figure it out
Old 03-24-2010, 02:29 AM
rustyolred's Avatar
Rep:20
I have a hayden 17" electric fan. 4 wires. 2 coming off of the fan motor and 2 coming off of the temp sensor in the radiator?
Old 03-24-2010, 12:31 PM
Color: All black
Rep:38
Four wires off of the fan, dual fan or is there a relay already wired in?
Sensor on the radiator with two wires sounds like a normal open thermal switch, correct ?
When all else fails
http://www.haydenauto.com/Installati...s/Content.aspx
Old 03-24-2010, 12:39 PM
rustyolred's Avatar
Rep:20
When all else fails
I looked on the Hayden website and nothing on there looks like what I am working with.
I have 4 wires total.
2 are coming from the single fan
2 are coming from the thermal switch. I do not know if it is normally open or normally closed though.
There is no relay that I can see.
Please help guys and gals.
Rusty
Old 03-24-2010, 12:41 PM
Color: All black
Rep:38
Rusty
Model numbers?
