Old 03-23-2010, 11:54 PM
ndgo88 ndgo88 is offline
Vehicle: 2004 Ram 1500 4.7 2WD
Trim Level: short bed QC
Color: Light Almond Pearl
ndgo88 is on a distinguished road
Unhappy New guy with question about rotor adapter removal
Hey guys! I have an 04 1500 QC. I decided after experiencing a wobble a slow speeds and vibration between 55-65 mph to change out my rotors and pads. Figured that maybe my rotors are warped. Approximately 10k miles ago I replaced the front two tires. This is my issue I need help with. The rotor adapter has two (21mm I think) bolts. I have sprayed them with Blaster to maybe get the bolts loose. No Luck there, the second problem is not getting enough leverage on bolts to remove them. So, I just replaced the front pads on both sides. Obviously the vibration did not go away. Any suggestions on removing these bolts? Any ideas or assistance would be greatly appreciated!!!
Thanks in Advance!!
NDGO88
Old 03-24-2010, 08:52 AM
RamTech RamTech is online now
Rep:1845
Rotor adapter??? Is the vibration only when you apply the brakes?
Old 03-30-2010, 06:50 PM
Yes, only when I press the brakes . . .
Old 03-30-2010, 07:03 PM
I think he's talking about the caliper holder .
Old 03-30-2010, 07:05 PM
They are tight . Just some good old muscle . Maybe try a breaker bar with a small piece of pipe . They'll come loose .
Old 03-30-2010, 07:06 PM
Rep:1845
Yup, most of the time it takes a 1/2" drive breaker bar with a cheater unless you have a really good impact.
Old 03-30-2010, 07:28 PM
Rep:2616
ROTOR ADAPTER ??
do you mean the calipers? the part that holds the brake pads?
http://www.car-stuff.com/includes/se...BvZiBvcmRlci4=
Old 03-30-2010, 09:10 PM
I push the skinny pedal
Rep:3277
I was confused too, pretty sure he's talking about the calipers since he's talking about only 2 bolts.
Kurtis
Old 04-01-2010, 01:58 AM
The manual says it's a caliper adapter. the calipers fit over the top of the adapter. The calipers came off easily, however there are an additional two bolts that hold the caliper adapter on. I have to remove it to take off the rotor. I think I will try the breaker bar. I have a 1/2 in breaker bar however it is hard to get enough leverage to break it loose.
Old 04-01-2010, 09:09 AM
Rep:1845
That's why you need a cheater pipe.
