Old 03-24-2010, 10:25 AM
vfly172 vfly172 is offline
vfly172 is on a distinguished road
Default Leveling kit options?
I have an 01 1500. I bought a 2" leveling kit, since that is whatI think most people run. The difference between wheel well heights was just over 2". Before install, I jacked the body up in the front so that the front wells went up 2". Now it looks like the front sits higher. 1.5" seems to be better. Will I not get a true 2" after install? I just dont want to go through the hassle of having to take them out after I put them in if the front will definately sit higher.
Old 03-24-2010, 10:42 AM
jkulysses jkulysses is offline
Vehicle: 2007 Ram Quad Cab
Trim Level: 2500 4x4 HEMI
Rep:68
jkulysses will become famous soon enough
If it's only sitting 1/2" higher in front it's not going to be extrememly noticeable and a lot of people actually prefer that look almost like a baja truck type look lol. Is your's coil spring in the front or torsion bar??
Old 03-24-2010, 11:07 AM
coil springs.
Old 03-24-2010, 04:58 PM
Rep:68
Check these out they give you 3 different levels of lift and a better ride. http://www.bilsteinus.com/leveling/index.php
Old 03-24-2010, 10:24 PM
DanoHB's Avatar
DanoHB DanoHB is offline
Vehicle: 2007 Dodge Ram 1500
Color: Electric Blue
Rep:32
DanoHB is on a distinguished road
Only if it is a 4x4 though. trust me, I have been down this road now, and if it is a 4x2, good luck.
-----2007 Dodge Ram Sport 2WD "Electric Blue"-----
Old 03-24-2010, 10:26 PM
ScatPak07's Avatar
Rep:970
For the Ram tey only make the leveling kit for the 06-08
Old 03-25-2010, 10:46 AM
MOPAR MULiSHA's Avatar
MOPAR MULiSHA MOPAR MULiSHA is offline
Vehicle: 2012 Dodge Ram 1500
Color: Sage Brush Pearlcoat
Rep:219
MOPAR MULiSHA has a spectacular aura aboutMOPAR MULiSHA has a spectacular aura aboutMOPAR MULiSHA has a spectacular aura about
2" seems to be the trend (I plan on getting a 2" aswell) and from the pictures I've seen i would say roll with the 2". I think it's going to be as close as your going to get.
2012 Sage Brush Pearlcoat Ram 1500 Big Horn Crew Cab Hemi 4x4 w/ Ram Box Storage System
Old 03-25-2010, 11:57 AM
Rep:68
Dang I almost opened up the application list too because I hate posting up wrong info but I was kinda in a hurry when I posted that lol. As for how much lift you need I thought mine was only going to need 1.5" in the front cause it looked like it was sitting higher than my cousins 1500 in the front so I took a tape measure and measured from the top of my tire to the fender both front and rear and it was almost exactly 2" higher in the back. the 2" turned out perfect on my truck and I couldn't be happier. My tire's stick out of the fenders a way's too so it made it pretty easy to just set the tape on the tire lol. I went with Daystar not sure if they make anything for your truck or not but just go to their website and check it out.
Old 03-25-2010, 11:58 AM
ScatPak07's Avatar
Rep:970
I knew cause I ordered some for mine haha. I even called them to make sure that it actually lifts the truck. I will be using the 5100s on the lowest level the .64" with my 2" spacer. This will give me close to 3" lift in the front. I also have a 2" block in the rear so I will be getting a more leveld look
Old 03-25-2010, 12:23 PM
Rep:68
Ya I wish I had another inch or so because these tires rub on the inner fender well sometimes at full lock and I go over a bump or incline at the same time like some speed bumps. It doesn't hurt anything but it's annoying and it seems to be worse on the drivers side which is weird lol.
