Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Towing
Place your Ad Here!
Old 03-24-2010, 11:28 AM
Zack Birge Zack Birge is offline
Vehicle: 2010 Ram 1500
Trim Level: Laramie Crewcab 4x4
Color: Black w/pearl
Rep:30
Zack Birge is on a distinguished road
Default 2010 hemi towing and shifting? Needs to quit
Guys I tow a bassboat all week and weekend pretty much. I have a issue with shifting. I can get up to 70-75 quick but it continuously shifts down to hold this speed even on minor hills. This is in tow and manual and regular drive. I'm sick of the shifting and I already bought a predator and exhaust trying to help this problem. What can I do to keep it holding speeds without shifting? Turbo/supercharger? Give me suggestions please
Old 03-24-2010, 12:31 PM
Resident Technician
Rep:1915
What rear end gears do you have?
Old 03-24-2010, 12:46 PM
What Randy ^^^^ asked is very relevant.
I just towed a small UHaul over three mountain ranges and when I got to the hills, I just put it in Tow/Haul and it didn't hunt for a lower gear nor did it shift up, then back down again very often.
I have 3.73 gears, FYI, and I don't have MDS either.
Old 03-24-2010, 01:07 PM
Rep:30
I have the 3.92 gears
Old 03-24-2010, 01:13 PM
And it does this in Tow Haul mode and OD off? Maybe it's MDS related. Not sure but then again, I don't have MDS. But I don't think MDS kicks in while it's hunting for the right gear.
Old 03-24-2010, 01:23 PM
Rep:30
Yep it does. And I disabled the mds with the predator
Old 03-24-2010, 01:36 PM
That is weird...seems to me in O/D off it will hold the gear.
Old 03-24-2010, 01:57 PM
Rep:30
Well it does until I slow down some then it kicks down
Old 03-24-2010, 02:17 PM
So if you are in tow/haul, it goes down a gear, right?
And if you are in O/D off, it also gears down?
What kind of grade are you pulling and what's the weight of the towed item?
Old 03-24-2010, 02:26 PM
Rep:30
Anything uphill at all it just bogs down it's a 2500 lb bassboat
