Old 03-25-2010, 08:08 PM
Zack Birge Zack Birge is offline
Vehicle: 2010 Ram 1500
Trim Level: Laramie Crewcab 4x4
Color: Black w/pearl
Rep:30
Zack Birge is on a distinguished road
So anything else I could do or add? What about a turbo or supercharger?
Old 03-25-2010, 09:58 PM
HoustonHemi's Avatar
HoustonHemi HoustonHemi is offline
Vehicle: 1492 Santa Maria
Color: Hot pink
Engine: 1981-1987 225ci (3.7L) Slant-6 95hp
Rep:135
HoustonHemi will become famous soon enoughHoustonHemi will become famous soon enough
How about a Cummins Turbo Diesel? =) Should pull 2500 lbs like a sum-beech!
(If it was me, I'd go that route before I went aftermarket turbo / SC.)
BUT, on a more serious note, there are other options available to increase your pulling power that are more reliable and cheaper than turbo / SC,,,
I don't know that the HEMI is really lacking for power, but it may not have the power (torque) you need in a certain gear at a certain speed.
In that case, you should consider trying lower finals,,, 4.56's,,,
Old 03-26-2010, 12:09 AM
Rep:2664
turbos & super chargers are for speed performance, not torque or shifting
i have to believe that there is a different solution
Old 03-26-2010, 12:44 AM
CHVYKLR's Avatar
CHVYKLR CHVYKLR is offline
Vehicle: 2009 Ram Crew 2WD
Trim Level: Lone Star
Rep:252
a twin turbo kit would be pretty expensive ($6k+) but would make a TON of torque.
Old 03-26-2010, 08:36 AM
Excoastie's Avatar
Vehicle: 2014 VW Jetta GLI
Color: Metalic Black
Rep:1358
if you don't have it already... you might look in to a tranny cooler kit... I've got the 3.55s in my '10 Sport HEMI CC. I haven't had anything hooked up behind her yet, but we will see in the weeks to come....
Exco
Bill
Old 03-26-2010, 09:36 AM
Rep:30
I just sold my 07 5.9 cummins it was a bad some beech literally. It had twins and everything. But wasn't reliable I kept having minor issues that I didn't want to put up with. So would like 4.56 gears hold more for for towing and let me pull better? How about the mileage?
Old 03-26-2010, 02:28 PM
CHVYKLR's Avatar
Rep:252
Here's something I posted in another thread but will help answer your question.
Here is the math @ 70 mph running the 275/60-20 tire (33")
3.92 = 1872 rpm
4.10 = 1958
4.56 = 2178
75 mph with same tire
3.92 = 2006
4.10 = 2098
4.56 = 2333
I used Randy's Ring and Pinion website calculator. I'm pretty sure 5th gear is 0.67 ratio. Keep in mind that if you use the Tow/Haul mode these calculations would all have to be redone for 4th gear.
Old 03-26-2010, 02:41 PM
Rep:2664
I accidentally hit the TOW/HAUL button when leaving a job site yesterday, my '09 ram went down to 5th & it went back to 6th as soon as I took it out of that mode
now i know what it does, i'm still discovering things about my truck & i've had it more than a year
Old 03-27-2010, 12:39 AM
chefred112's Avatar
Vehicle: 2005 Dodge Ram
Rep:656
what I havent seen yet..what size wheels/tires you runnin? stock? 4.56's would definitely keep the gears from huntin..
-fast freddie- one quick 05 hemi qc...with over 275k miles on odo... on the 5.7, stoker 6.4 now...Inertia Motorsports 392 stroker
Old 03-27-2010, 08:13 AM
Rep:30
285/65/18 nitto Terra grapplers
