2010 hemi towing and shifting? Needs to quit - Page 3 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Towing
Old 05-11-2010, 09:52 PM
Raptor1000R's Avatar
Raptor1000R Raptor1000R is offline
Vehicle: 2010 Ram 1500 4x4 Sport Crew
Trim Level: Sport, buckets, RER
Color: bright white
Raptor1000R is on a distinguished road
Zack, I don't get it. I have 3.55 gears and same truck, heavier boat and it pulls great as long as I have it in tow/haul mode (mds on vs. off didn't change for me when pulling). Do you pull at 60-65mph? It seems all truck/vehicles have a hard time with 60-65mph when pulling, they do better at 70+ for shifting, unless you have 32" tires and 4.10 gears. I'm really surprised you're having so much shifting with 3.92's. hmmmm????? sorry dude, guess you'll need a Cummins next round!
2010,15004x4,Hemi,Sport,White,Crew,CAI,Predator,Li ne-X,Truxedo Lo Pro,2"level kit,PE Powergate
Old 01-18-2011, 12:46 PM
zman9788 zman9788 is offline
zman9788 is on a distinguished road
I too experienced these issues. First off, I believe someone posted that it is a 6-speed tranny. I am pretty sure it is only a 5-speed. Tow/haul just changes shift points slightly. After a few hours of shifting up and down, I finally remembered I had the digital gear shifter. Put it in 4 and it runs at 2500 rpm with 4000 lbs. at 60-65mph. it doesn't gear down unless you go up a really steep hill. Run at 70 mph, and it will shift down a lot more on even minor hills. I don't have an O/D off button. I only have a Tow/Haul and I asssumed 5th was my overdrive. I may be completely mistaken with all of this info, but 4th seemed to work great. I got a Mufflex 18" on my truck and the constant shifting was getting annoying.
Old 01-18-2011, 01:48 PM
Resident Technician
Rep:1915
Are you sure it's kicking down a gear or is it the torque converter unlocking?
Old 01-18-2011, 01:50 PM
Resident Technician
Rep:1915
Technically speaking it is a 6 speed transmission but because of the 2 second gears, it's classified as a 5 speed. The extra second gear is a true passing gear and isn't used in upshifting. Check out this link for more info http://www.ramforumz.com/showthread.php?t=55657
Old 01-18-2011, 10:48 PM
dafoot dafoot is offline
Vehicle: 2017 Dodge Ram, 1500, Hemi
Rep:16
dafoot is on a distinguished road
I have 3:55 gears and pull around 4500 pounds. You are lucky to have 3:92s. Always pull in 4th gear. That should solve your problem. My experience with tow/haul does nothing more than change shift points when going up in gears. Turns off mds. No difference with torque converter staying in lock up. In driving gear, truck acts the same with or without tow/haul.
DAFOOT
Old 01-19-2011, 12:14 AM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
The only impact Tow/haul has on MDS is it increases the rpm beyond the MDS's operational range.
To turn off MDS you have to put the trans in manual mode.
Brian:
Old 01-19-2011, 09:31 AM
Rep:16
^^^ That makes sense. When pulling the boat, I am in 4th gear, so the mds is off. For my use, tow/haul makes no difference. I supose it would if I where pulling more weight.
DAFOOT
Old 08-27-2016, 09:22 PM
homerunhitter homerunhitter is offline
Vehicle: 2014 1500 Longhorn
Trim Level: Longhorn
homerunhitter is on a distinguished road
I have the same problem!!!! I have a 2014 5.7 Hemi with asupercharger with a lift kit and 35" tires. All that said my truckis great until I exceed 60mph. 60-70 it shifts back and forth constantly.
  • 3.21Rear Axle Ratio
  • 3.21Rear Axle Ratio (Requires EZH)
  • Transmission:8-Speed Automatic (8HP70)
    In speaking with ProCharger,they have no codes for the transmission. In speaking with Diablo (thecompany that ProCharger uses for their tune)- they feel that it's the 35"tires are causing everything being thrown off. In speaking withExtreme Offroad (who did the install)- they want me to experiment with largergears and that it "might" fix the problem. But in talking with alocal dealership they said they had codes for the transmission and mentionedsomething about "flashing" or something like that and felt hopeful.
    I’m lost but am just superunhappy with the gas mileage and with the overall performance. I average 10mpg and road trips are just “messy”…
    Anyone have thoughts orexperiences they could share?
