Factory Spec: 5.7-liter HEMIŪ V8 engine - 390 horsepower, 407 lb-ft of torque.
Old 03-24-2010, 11:45 AM
Zack Birge Zack Birge is offline
Vehicle: 2010 Ram 1500
Trim Level: Laramie Crewcab 4x4
Color: Black w/pearl
Rep:30
Zack Birge is on a distinguished road
Exclamation Predator adjustments???
This might be a dumb question but here we go, what are the differences if I adjust the WOT SPARK, or the adjustment that makes it more rich or lean??? I know its stupid im use to diesels, I have no Idea on gas trucks?
Old 03-24-2010, 01:06 PM
I'd leave the WOT spark alone and add or delete fuel depending on your Air/Fuel ratio reading. WOT spark adjustments are best left to a qualified tuner.
If you have a shop with a dyno in your area you can get an A/F reading pretty easily.
At WOT, if you are running above 12.5 A/F, you are running lean and should add some fuel. If you are below 12.5, it's a bit fat but I'd leave it alone.
I suspect you are running lean as that's the factory default and loading a Predator on the truck with one of the canned tunes does not adjust your fuel.
There's a How To attached to this post that may be helpful to you.
Do this at your own risk. Or, talk to DiabloSport. Another alternative is to go see a DiabloSport Authorized CMR tuner.
