Rear end problems - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Suspension
Old 03-24-2010, 12:47 PM
jeff9760 jeff9760 is offline
jeff9760 is on a distinguished road
Default Rear end problems
so my 2009 dodge ram 1500 laramie, driveshaft dropped out of it pulling in to the dodge dealrship to get a rear end noise looked at. so far the dealership says that the yolk broke and they are looking into the reason why. this is the second time this has happened with only 28000 miles. attached photos.
update: the dealer says a nut backed off and got into the ring and pinion so the whole rear end is shot.
Old 03-24-2010, 03:44 PM
mineralram's Avatar
mineralram mineralram is offline
Vehicle: 2017 Dodge Ram
Color: Black Pearl Metallic
Rep:176
mineralram has a spectacular aura aboutmineralram has a spectacular aura about
now that sucks big time sorry to hear man
Old 03-24-2010, 03:56 PM
UN4GTBL's Avatar
UN4GTBL UN4GTBL is offline
Vehicle: 2007 Dodge Caliber
Rep:41
UN4GTBL is on a distinguished road
wow. that sucks for sure.
keep us updated on this
2007 Dodge Caliber SXT - 1.8L I4 & 5-Speed Manual
2011 Dodge Grand Caravan SXT Plus - 3.6L V6 & 6-Speed Auto
Wanting a new Ram...
Old 03-24-2010, 04:53 PM
Maybe they should drill the fastener and safety wire it!
Sorry for your troubles.
Old 03-24-2010, 05:35 PM
Cormacs's Avatar
Cormacs Cormacs is offline
Trim Level: Crew Sport
Rep:14
Cormacs is on a distinguished road
I have seen that a few times and it was due to a pinion seal leak. The differential leaked so much over time that it got too low and then the bearing's get too hot and it shears the pinion off. The tell tale sign is differential fluid on the side of the gas tank.
Old 03-24-2010, 08:17 PM
Warwagon's Avatar
Warwagon Warwagon is offline
Vehicle: 2015 Hellcat
Color: Sublime pearl green
Rep:71
Warwagon will become famous soon enough
Default Rear end issues
Thought I'd post up as well, my pinion seal started leaking a couple days ago and I have an appt. to have it replaced on Mon. next week.
I only have 24,000kms on mine, just a heads up, you folks might wanna check yours to
Aspire to inspire before you expire
Old 03-24-2010, 10:27 PM
I would have to say that this is not the first time I've seen this . It actually happened to me in my first car . Nut come off the pinion . Started with a slight whinning noise then kapowwy . DONE .
Old 03-24-2010, 11:02 PM
HoustonHemi's Avatar
HoustonHemi HoustonHemi is offline
Vehicle: 1492 Santa Maria
Color: Hot pink
Engine: 1981-1987 225ci (3.7L) Slant-6 95hp
Rep:135
HoustonHemi will become famous soon enoughHoustonHemi will become famous soon enough
My pinion seal was leaking at only 3,500 miles,,,
Yep, oil on the gas tank, with oil 'spots' slung around on the rear suspension.
Old 03-25-2010, 06:43 AM
Cormacs's Avatar
Rep:14
The rear pinion seal and the right front axle seal are the most common seals on these trucks to leak. I have seen them leak as little as 3000 miles. Infact my right front axle seal is sweating already and I only have 3000 miles on mine.
Old 03-25-2010, 01:30 PM
Color: Hot pink
Rep:135
Cormacs,
From what you have seen, what is the root cause of these issues?
Seal not installed correctly from the factory?
Also, do individual vehicles that have seal problems eventually have the same problem again,,, even after the seals have been replaced?
problems, rear end, yolk
