Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Suspension
Old 03-25-2010, 06:41 PM
MightyBlueRam's Avatar
MightyBlueRam MightyBlueRam is offline
Vehicle: 2014 Ram 1500 EcoDiezl Laramie
Trim Level: Laramie 4x2
Color: Blue Streak Pearl Coat
Rep:432
MightyBlueRam is just really niceMightyBlueRam is just really niceMightyBlueRam is just really niceMightyBlueRam is just really niceMightyBlueRam is just really nice
Wow that sucks big time! I've never see that happen before.
Old 03-25-2010, 08:17 PM
Cormacs's Avatar
Cormacs Cormacs is offline
Trim Level: Crew Sport
Rep:14
Cormacs is on a distinguished road
It is ussually a long time coming. The seals do wear out and unfortunately they wear out within a short amount of mileage. Regular inspections of the seals and fluid levels can prevent major repairs. As long as it was a seal leak that lead to your problem. It may have been just the nut backing off, I have never seen it before but it is possible I guess.
Old 03-25-2010, 10:40 PM
HoustonHemi's Avatar
HoustonHemi HoustonHemi is offline
Vehicle: 2014 Ram 1500 Quad
Trim Level: Lone Star
Rep:135
HoustonHemi will become famous soon enoughHoustonHemi will become famous soon enough
The dealer fixed mine under waranty, so we never will know exactly 'what they found',,, Just hoping this isn't a 'regular' event....
Had a chevy 1 ton with the 'heavy' (?) rear end (hubs seperate from axles)
Right rear seal went out twice in 38,000 miles,,,
As it was then just out of warranty, I replaced it myself.
Shoot, the preload on the hub bearings on that side was so loose, the hub would 'clunk' back and forth,,, (You know what I mean!) The retainer was fine, the tech at the chevy dealer just set the preload way too loose when he replaced the seal the first time. (He also managed to cross thread a lug on the front spindle, too!!!)
I Re-used the same bearings and races, just put in a new seal and the correct preload.
No troubles whatsoever for the next 100,000 miles,,,, (Might still be going strong today, I don't have the truck anymore)
I have a great dislike for incompetent mechanics.
Thanks for your info, Cormacs!
Old 03-26-2010, 10:15 AM
Cormacs's Avatar
Rep:14
Unfortunately there is a lot of people with tool boxes out there, just not very many mechanics. Trust me I know, I work with a few of them.
Old 03-26-2010, 04:59 PM
SPEEDFREAK's Avatar
SPEEDFREAK SPEEDFREAK is offline
Vehicle: 2010 RAM R/T
Trim Level: 450HP & 450TQ
Color: SPEED WHITE
Rep:180
SPEEDFREAK has a spectacular aura aboutSPEEDFREAK has a spectacular aura about
Default Problem with your rear
that was going to be my same responce, becareful who works on it. the rear gear in my 09 ram was winning took it in to get fixed they said they replaced it. 2,500 miles later it was winning agine. i wanted to smack someone. i had 03 ram hemi never had a winn problem
k&N CAI, 3 1/2" 90 on CAI at TB, 85mm BBK TB,denso sp,180stat,syn oileng & rear gr,Catchcan, Addco sway bars f&r
1 3/4"amer rac hders high flowcats, 2 1/2" H pipe dul 2 1/2" piping, Diablo CT, Bilstin, Mcdrop 2/4,1deg cam 295/45-20bfgkdw,efan,13.4gtech
Old 03-26-2010, 11:11 PM
Cormacs's Avatar
Rep:14
Rear ends are very picky. If you build them right, they will last forever. If you build them the slightest bit wrong it will not take long until there is a failure.
Old 03-31-2010, 07:47 AM
Warwagon's Avatar
Warwagon Warwagon is offline
Vehicle: 2015 Hellcat
Color: Sublime pearl green
Rep:71
Warwagon will become famous soon enough
UPDATE:
I took my truck in for the pinion seal on Monday morning, they replaced the seal BUT told me that was NOT leaking in fact the Flange around the pinion is leaking!!
The tech said he fixed it but I should keep an eye on it?
HOW? The flange is part of the casting? Short of putting a new rear end in this truck I don't see how they'll fix this problem?
The truck leaves a puddle the size of a deck of cards everytime I park it
Well approximately 400kms later it's leaking again only Worse! Not even a full day since repair!
Truck is going back in today for another try
Not Impressed, brand new truck (6months old) and it has been pampered since new.
Aspire to inspire before you expire
Old 03-31-2010, 04:47 PM
Warwagon's Avatar
Rep:71
Well another Frustrating day with my dealer!
They wanted to just replace the driveshaft flange,pinion nut and crush washer and call it a day! I said NO FREAKING WAY!
I asked them to disassemble my rear and find out what the cause is, why is oil running down the pinion gear and out the flange and nut???? Pinion seal is FINE!
Not only that but the oil in the diff has only been in there for 400kms and it looks like sludge! How long will the rear last like that? LOL
They agreed to disassemble, check tolerances and reassemble with new flange nut etc.. And I was told Dodge would replace the entire rear if it leaks upon return to me?!
Sounds fair, I just hope they get it fixed this time cause I really like this truck!
I'll update again once I have my truck back for now I'm driving a PT Crusier rental which sure doesn't have a hemi
Old 04-01-2010, 12:07 AM
Rep:135
Frustrating, I know,,,
It sounds like they are trying to 'resolve' it, but about all you can do at this point is hope they get it RIGHT ASAP!
Keep us posted!!!
Old 07-20-2010, 08:00 PM
zrock zrock is offline
Vehicle: 2002 dodge ram
Color: Inferno Red
zrock is on a distinguished road
that is so true about fluid on gas tank. I just noticed a leak under my universal joint and fluid on the tank. after further research it was the pinion seal.
problems, rear end, yolk
