Old 03-25-2010, 02:43 PM
live2ride live2ride is offline
Vehicle: 14 1500 5.7 CC 6.4 8sp
Color: Maximum Steel
live2ride is on a distinguished road
Default 2 quick questions
1...
My front end skreetches when it bouces... when ever it moves up and down..
I lubed the chit out of my front end where it was skreetching and after a few months it comes right back...
any way to stop the skreetching?
2...
My driver side door vibrates with the wind as if its not closed all the way... it gets pretty annoying... any easy way to fix it?
2005 dodge ram crew cab 1500 5.7L hemi- cat back Gibson exhaust, Superchip, Intake spacer, BBK CAI, 4" Rancho Susp lift, 17x9 -8mm ion alloy 133 rims with 370-70 terra tracs SOLD
2014 Ram 1500 CC longbox hemi big horn, 3.92 gears 121L tank
Old 03-25-2010, 02:53 PM
Sounds like a worn out bushing. What kind of lube are you using? Try some spray on white lithium grease. That lasts the longest.
Check the alignment and weather stripping on the door. Make sure the door fully closes and latches. Check the weatherstripping for any folded over or loose sections.
Old 03-25-2010, 03:26 PM
the first time round I just used wd40 just to make sure I found the right spot... then I used some kind of spray on grease my old man uses...
It lasted a little while but i think front going through back roads n mud n then washing the truck i just took out all the grease... I though it was a worn out bushing as well... but my old man checked it out and it didnt look like it was worn out... Ill have to find some time and take it apart... just kinda tuff to do since its my only mode of transportation at the moment...
I checked all the door alignment and the striping and all... its just the top top part of the door that doesnt seem to close even with the truck... as if the top part was bent or something... I went to a mech and asked what i could do... he said most places would just bend the door so its back tight.... did something in those lines it worked for about a week then went right back to the way it was...
Old 03-25-2010, 04:09 PM
Sounds like either your door hinge is mis-aligned or the door is sprung.
Old 04-01-2010, 12:43 PM
how could you fix it if its sprung?
hmm guess id need new hinges if they are messed?
its wierd... the creeking comes and goes... not always constant
