Old 03-15-2011, 03:36 AM
CapperRAM's Avatar
CapperRAM CapperRAM is offline
Vehicle: 2013 RAM Power Wagon
Trim Level: Power Wagon
Rep:205
CapperRAM has a spectacular aura aboutCapperRAM has a spectacular aura aboutCapperRAM has a spectacular aura about
Default Reworking the Throttle body butterfly for HP gains????
Maybe a question for Ramtech?? I work with a guy who knows a guy...... who is a dodge mechanic! He says he can do some work to the butterfly in the TB to see big gains in HP and MPG?? Does this sound achievable or is someone blowing smoke??
Old 03-15-2011, 04:11 AM
98sst's Avatar
98sst 98sst is offline
Vehicle: 1998 Dodge ram 1500
Trim Level: SS/T
Rep:883
You would not see big gains. Typically, the only time TB modifications will do much will be if you have an aftermarket intake manifold accompanied with aftermarket heads/cam as well. Aside from that, you wouldn't feel much difference!
If the guy is reputable, I guess you could let him work with it if you plan on modding heavily down the road. I'm assuming he will be boring it out a bit. It's a meticulous process and if it's bored too much you'll be losing power rather than gaining. The stock TB is typically the best it will get for the stock setup.
Old 03-15-2011, 07:51 AM
Rep:1824
I think he's blowing smoke. I don't see how you'd get big gains by modifying just the butterfly. To get a gain, you need to flow more air which would require opening up the TB itself, not the butterfly. I could, however, see potential for high idle problems if it were done wrong.
Old 03-15-2011, 08:20 AM
HEMILANCER's Avatar
HEMILANCER HEMILANCER is offline
Vehicle: 09 Dodge Ram
Color: deep water blue
Rep:85
HEMILANCER will become famous soon enough
maybe he'll put a nitrous nozzle in there?
Too many mods to fit here!
Old 03-15-2011, 10:24 AM
chefred112's Avatar
Vehicle: 2005 Dodge Ram
Rep:650
it may show slight gains..my tb is ported and the blade knife-edged...to really take advantage you want a good cai/exhaust and maybe a cam/head setup down the road... is it gonna cost you? wiegh that vs the benefit...when ported tb's first came out they were around $400. They have since come down quite a bit nowadays..
-fast freddie-
one quick 05 hemi qc...with over 250k miles on odo... on the 5.7...stoker 6.4 now, new times coming
performance mods: yes 1/8 - 7.85 @ 93.20, 1/4 - 12.10 @ 113.96
Throttle Body Cleaning Procedure RamTech Dodge Ram Knowledge Base 49 02-05-2014 03:02 PM
ETC Throttle Body Cleaning Procedure RamTech Dodge Ram Knowledge Base 8 01-30-2014 05:53 PM
Trasmission Help!!! bigjeff64 5.9L V8 Specific Topics 12 02-28-2010 09:58 PM
