Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > Dodge Ram Knowledge Base
Old 03-27-2010, 11:41 AM
gregor413 gregor413 is offline
Vehicle: 1997 Dodge Ram 1500 Club Cab
Trim Level: Sport 4x4
Rep:16
gregor413 is on a distinguished road
Default How to install new Shocks with the wrong tools
Hello all. I just got finished with a prety simple install I made longer and more dificult due to broken and incorrect tools so I figured I would save everyone else a little time when they are ready to do the job.
First off Changin the shocks is a simple one person job with limited tools needed. Second, make sure you have the right tools, new shocks with bushings, some sort of penetrating oil (WD-40) and about 2 hours to kill.
For shocks I ordered Skyjacker Nitro 8000's from Autoanything.com for about $170 for all 4 shipped (not bad I thought). They come with all the bushings and new top nut but you have to use the old mounting bolts so if they are rotted or broken make sure you get yourself some new ones.
I soaked the nuts and bolts with wd-40 the day before so it soaked in nicely.
I removed the spare tire so it was nice and easy to sit under there and get the rears off. You will need 2 21mm sockets or wrenches (I reccomend one of each) and make sure you have a nice long Socket wrench for leverage, it will make your life that much easier. I unfortunately had a broken 1/2" socket wrench so I had to use my braker bar instead which is why it took me so much longer to do the job. Of corse if you have air ratchets by all means use em. The Nuts on mine had a bar welded to them so you really only needed the one wrench to remove them but I can imagine some of them getting broken off or bent. The rear should take about 30 minutes or less depending on your tools and the rust factor.
The fronts take about the same amount of time although it did take a little time removing the bottom of the shocks from the chassis, I had to pry from below while my son wiggled the top from front to back. To remove them you need to remove the 3 15mm nuts holding down the top mount bracket. The new front shocks are easier to install when they are compressed so I would suggest reusing the wire the new shocks come with to hold them compressed and then cut it once the top mount bracket is back in place and the bottom bolt is also.
All and all it was a simple job and I would say anyone with these tools can do. And the reward of a smooth riding truck is awesometastic!
I hope this will help any of you who have this job ahead of you. Dont be scared it's easy!
Give me some tools, beer and something to fix and I will show you a happy man.
Old 03-27-2010, 11:44 AM
Rep:1909
If you have access to a lift and air tools, by all means, use them. The job can be done in under an hour.
Old 03-27-2010, 09:21 PM
Incognito's Avatar
Incognito Incognito is offline
Vehicle: 2003 Dodge Ram 1500 Crew Cab
Trim Level: 5.7L Hemi 4x4
Color: Graphite Gray
Rep:72
Incognito will become famous soon enough
I wish my Audis were as easy to work on as the Rams.
Old 03-27-2010, 09:38 PM
Rep:16
Im a VW guy so I feel your pain.
Old 05-10-2010, 01:34 AM
Valldar's Avatar
Valldar Valldar is offline
Vehicle: 2006 Ram 1500 - 5.7L HEMI 4x4
Rep:60
Valldar will become famous soon enough
Ya, the Germans make good cars, but good-old American made is where its at!
ERIK
-=UPGRADES=- Focal K2 Component Speakers // 2x Boston G210-44 Subs // 2x JL 500/1 & 300/4 Amps // Rhino Lining Bed // Grillcraft Black Grille // 35w 5000k HID Fogs // 50w 6000k HID Heads // 0 Gauge Engine Wire Upgrade
Old 05-10-2010, 08:58 AM
iRESQu iRESQu is offline
Rep:2217
Nice write up. Thank you! I'm glad that in the end it worked out great for you!
Old 05-21-2010, 08:29 AM
Rep:16
Well its been a month or so and I love these shocks. So far so good!
Old 07-08-2010, 05:24 PM
02haynram's Avatar
02haynram 02haynram is offline
Vehicle: '02 QC Ram
Rep:19
02haynram is on a distinguished road
lol, i just had to have my shocks changed. This is my 1st full size Vehicle, so I wasn't really equipped/ready for the job at hand(and it's only changing shocks). I have always only owned imports(Trucks & cars). So I had to purchase a full-size service jack because my jacks were to small. On top of that, I only have 3/8" Drive ratchets/breaker bars/sockets/etc(maybe a few 1/2" deep sockets for impact). So another words, I only have a set-up for imports. After about an hours, a few slips off the nut/bolts, a few bruises to my arms & ego, I opted out and just took the truck to our local performance shop. for $60 on-top of the total for the shocks, I waited for maybe 30-min. To me was worth the extra $60 to have them change out. No worrying about stripped hardware & gained a warranty. In the mean time, I have to update my tools. lol
Old 07-14-2010, 08:34 PM
moparmike07's Avatar
moparmike07 moparmike07 is offline
Vehicle: 07 dodge ram 1500
Trim Level: st
Color: silver
Rep:68
moparmike07 will become famous soon enough
no pics not a believer
2007 dodge ram 1500 quad cab 4x4 5 percent tint all around 35 percent windshield, ported tb, diablo sport, arh headers, magnaflow dual exhaust, magnaflow y pipe, krc210x cam,nitrous,CNC ported head. 4.56 motive
