Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > 5.2L V8 Specific Topics
Place your Ad Here!
Old 03-27-2010, 12:49 PM
kicknjeep kicknjeep is offline
Vehicle: 1995 Dodge Ram 1500
Rep:26
kicknjeep is on a distinguished road
Default Tranny adjustments!
OK did the search and to no avail...But is it the same procedure for adjusting the 46RH bands as it is for the 46RE?. If not does anybody have a write up for this. TIA, Dan
Old 03-29-2010, 12:50 PM
Rep:26
Also does anybody have diagrams of where each electrical connections go?, I have one connector that is hanging and cannot find a place for it to plug into.
As you can see it has 2 female prongs. Tranny shifts fine but doesn't seem to want to kick down when throttle is applied. TIA.
Old 03-29-2010, 01:44 PM
Resident Technician
Rep:1915
Band adjustment is similar but has different specs. The procedures for the 46RH are as follows:
Front band: 1 - Loosen the adjuster locknut. 2 - Tighten band adjusting screw to 72 in. lbs. 3 - Back adjuster 2.5 turns. 4 - Hold the adjuster in place and tighten the locknut.
Rear band: 1 - Remove pan. 2 - Loosen band adjusting screw locknut. 3 - tighten locknut to 72 in. lbs. 4 - Back off adjusting screw 2 turns. 5 - Hold adjuster in place and tighten locknut.
Old 03-29-2010, 01:46 PM
Resident Technician
Rep:1915
I'm not sure where that plug goes but if you give me the wire colors and location of the plug, I'll try to run it down.
Old 03-29-2010, 02:03 PM
Rep:26
Thanks Randy, As for where the plug is it exits the wire loom just short of where the t-case shifter starts on the floor board (if that makes sense). and sticks out about 6" from the loom. I'll have to wait until tomorrow before I can crawl back under the truck to see if I can see any wire colors (already in uniform for work)..
Resident Technician
Rep:1915
Ok, I'll do some research in the mean time. Is this for your '95?
Old 03-29-2010, 04:46 PM
Rep:26
Yes this is for my 95.
Old 03-30-2010, 11:15 AM
Rep:26
Ok checked and there is 1 purple and 1 black wire with a blue seal. I hope someone can figure this out because it is driving me crazy trying to find where this goes......
Old 03-30-2010, 12:28 PM
Resident Technician
Rep:1915
I'll get looking in a few and let you know.
Old 03-30-2010, 12:54 PM
Resident Technician
Rep:1915
Just to make sure I'm clear on this, is it in or under the cab near the shifter?
