ZDOG
Old 03-28-2010, 03:26 PM
CHVYKLR's Avatar
CHVYKLR CHVYKLR is offline
Vehicle: 2009 Ram Crew 2WD
Trim Level: Lone Star
Rep:252
turbo392, I completely agree that turbo lag is just a problem from years ago. With today's tech a 5.7 HEMI would spool a pair of 57mm turbos or one 76mm almost instantly. I never asked the OP what gears he had so that would play a part in getting the turbo to load.
I wouldn't be surpised to see 475rwhp from a conservative custom tuned setup set to 8-9psi and the torque curve would be nice and flat starting around 3k rpms.
Old 03-28-2010, 10:56 PM
supercharged03hemi's Avatar
supercharged03hemi supercharged03hemi is offline
Vehicle: 2003 ram 1500
Color: graphite
Rep:35
supercharged03hemi is on a distinguished road
Send a message via Yahoo to supercharged03hemi
I like both superchargers and turbos, but I like the superchargers more. Theres nothin like the whine of a supercharger
Old 03-28-2010, 11:13 PM
I push the skinny pedal
Rep:3308
Whoops forgive me guys, fingers got ahead of the brain, happens from time to time, I'd been thinking of the Kennebell gimme a break, i've been working 14 hour days for the last 2 weeks and am a bit squirley. As for the turbo lag, I'm so used to working with turbo diesels that I'm so used to a big lag when pushing 50+ psi I just expect it in every application.
For the limitations of the bottom end, 500 crank HP is a conservative number, and this would be a good time to start looking at upgrading your tranny anyway, and a good time to tear into you engine and get some forged or cryo'd internals and a new set of pistons, maybe upping the compression a bit.
Kurtis
Old 03-29-2010, 08:22 AM
CHVYKLR's Avatar
Rep:252
Cd, no harm no foul. I just wanted him to get good info. People can debate the s/c vs t/c forever but in the end he'll have a grin from ear to ear with either.
Old 03-29-2010, 10:26 AM
Rep:3308
Ain't that the truth!
Kurtis
Old 03-29-2010, 10:37 AM
Zack Birge Zack Birge is offline
Vehicle: 2010 Ram 1500
Trim Level: Laramie Crewcab 4x4
Color: Black w/pearl
Rep:30
Zack Birge is on a distinguished road
Ok fill me in on this question sorry not jacking the thread
I don't have anthing done to my truck except wheels tires, and a predator and exhaust. I tow a bassboat to and from tournaments A LOT! I am trying to decide if I want to do a supercharger or turbo? But I am not going to if I have to rebuild tranny and other engine parts. I had a 07 cummins and I know how all these things fall in a line with a diesel, but not so much with a gas engine. Will the tranny be able to stand up with the supercharger or turbo while towing??? How much more hp will I be looking at? Im most curious to know if it will help keep the tranny from shifting on minor to major hills as much as it does now due to the increase in HP?
Old 03-29-2010, 10:54 AM
droshemiram's Avatar
droshemiram droshemiram is offline
Vehicle: 03 dodge ram HEMI
Color: atlantic blue
Rep:89
droshemiram will become famous soon enough
Turbo or Supercharger Its a hard decision either way you'll feel the power in both.good luck on what ever you pick,let us know what you decide and your results.
Old 03-29-2010, 10:56 AM
Resident Technician
Rep:1911
Superchargers will give you the low wnd grunt you're wanting for towing. Turbo's are nice but i'd rather be BLOWN!
Old 03-29-2010, 10:58 AM
Rep:30
I'M looking for the best for towing and most reliable that won't jepradize my truck
Old 03-29-2010, 11:23 AM
Rep:3308
Most intercooled 'chargers will give you a 40-50% gain over stock HP. You'll get more if you upgrade the top end, but simply bolting on a 'charger won't require a tranny rebuild, you could get a higher stall torque converter, but not a requirement. As for towing, you should get better shifting since there's more torque behind the tranny now and won't have to downshift as soon to keep the RPMs up.
If you do a lot of driving, I highly recommend getting a turbocharger or an oil tapped supercharger (not a self contained one) since you'd be swapping out the oil quite regularly in the charger, and it's expensive if you use the stuff they recommend.
Here's the list that I follow for build up a driveline (most experience with diesels)
<500HP <600ft-lbs tq
stock drivetrain is adequate
suggest upgrading to a 2500RPM stall torque converter
>500HP <800HP <900ft-lbs tq
tripleloq ATS torque converter
billet flywheel(flex plate)
basic transmission overhaul kit
billet input shaft
transmission cooler + deep belly pan
800+HP, 900+ft-lbs tq
fivestar torque converter
billet flywheel (flexplate)
master transmission overahul kit (clutches + more)
billet input/output shafts
valve body
tranny cooler + deep belly pan.
Kurtis
