Will Smith and Wesson or Samuel Colt.... - Page 2 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > LD RAM - General Discussion
LD RAM - General Discussion RAM 1500 General Chat. Please post your tech questions in the HELP Zone!
Old 03-28-2010, 03:44 PM
Michelle's Avatar
Michelle Michelle is offline
Vehicle: 2001 Dodge Ram 1500
Trim Level: Laramie SLT
Color: silver
Rep:12
Michelle is on a distinguished road
where is the ecm at? cannot find any reference to it in the chiltons book
~Dodge Damsel~
Old 03-28-2010, 03:51 PM
Resident Technician
Rep:1915
There is no ECM in your truck - they're only in models with the 5.9 CTD. Your truck has a PCM which is located in the engine compartment.
Old 03-28-2010, 03:57 PM
Michelle's Avatar
Color: silver
Rep:12
thank you for you help hopefully can get somewhere with it without having to put it in the shop..
~Dodge Damsel~
Old 03-28-2010, 04:03 PM
Resident Technician
Rep:1915
If you want to go after this yourself, you'll need a DVOM a jumper wire and and a light capable of drawing a couple of amps to load test the wiring. Each circuit will have to be checked for a short to ground, short to power, shorted together, open circuit and load tested. You'll also need to closely check all the pin connections for corrosion, damage or looseness. If the wiring checks out you're probably looking at a bad PCM.
Old 03-28-2010, 06:11 PM
Michelle's Avatar
Color: silver
Rep:12
whoever had the truck before me had it wired incorrectly now we have it wired correctly and the computer reads it blew two codes #1 P0720 and #2 P0601 1st one says output speed sensor which we have replaced cleared computer now only blows 2nd code which book says internal control module memory check sum error 53 so does this mean have to replace whole pcm or is it servicable? thank you for all your help
p.s. speedo still not working properly
~Dodge Damsel~
Old 03-28-2010, 06:17 PM
Resident Technician
Rep:1915
A P0601 is a one step diagnostic. If the code is present, the PCM must be replaced.
Old 03-28-2010, 06:29 PM
Michelle's Avatar
Color: silver
Rep:12
Anybody have an extra one of those laying around...LOL That part is almost $400 new...grrrrrrrrrrrrrrrrrrrr!!!!!!!!!!!!1
~Dodge Damsel~
Old 03-28-2010, 06:36 PM
Resident Technician
Rep:1915
Plus, you'll have to have it flashed after installation.
Old 03-28-2010, 07:21 PM
Michelle's Avatar
Color: silver
Rep:12
and that means?? flashed??
~Dodge Damsel~
Old 03-28-2010, 07:57 PM
Resident Technician
Rep:1915
Programmed.
