Old 03-28-2010, 01:05 PM
04ram4X4's Avatar
04ram4X4 04ram4X4 is offline
Trim Level: Off Road Package, ST
Color: Blue
04ram4X4 is on a distinguished road
Send a message via Yahoo to 04ram4X4
Default Check engine light?
I just got my Bad Boy out of the shop and it's running perfect but this morning my check engine light popped on when I cranked it. Like I said running perfect. They had the heads reworked and new valve springs installed. When I picked it up and the next day it was not on then I cranked it this morning and BAM there it was growling at me like a rabid dog. Any ideas? Or where should I start looking? It's still running perfect but I want it off (not unplugged).
Old 03-28-2010, 01:09 PM
Rep:1885
Start by finding out what the code is. Could be something as simple as a sensor that worked loose or something more serious.
Old 03-28-2010, 01:14 PM
04ram4X4's Avatar
Color: Blue
Can I get the code without going back to the dealer? It wiped me out getting it out of the shop and funds are almost nonexistent. What I mean is can I get the code for FREE.
Old 03-28-2010, 01:28 PM
Rep:1885
You can try the on-off 3 times with the ignition switch or see if a local parts store will pull them for you.
Old 03-28-2010, 01:39 PM
Rep:2657
you might try doing the key dance, it costs nothing but time
here is an article that you want to read, sort of explains it
http://www.allpar.com/fix/codes.html
you might drive to the auto zone store, although their code readers are often wrong
I see Remerson already mentioned that
Old 03-28-2010, 02:01 PM
Rep:1885
It's not that their readers are wrong as much as it is that they won't read manufacturer codes, only generic codes. Keep in mind that just because you show an O2 code, the sensor isn't necessarily the cause. Codes are meant to be a guideline as to what component or system needs diagnosis.
Old 03-29-2010, 04:37 PM
04ram4X4's Avatar
Color: Blue
Thanks for the link. I'm going to do it as soon as I get off work.
Old 03-29-2010, 05:26 PM
droshemiram's Avatar
droshemiram droshemiram is offline
Vehicle: 03 dodge ram HEMI
Color: atlantic blue
Rep:89
droshemiram will become famous soon enough
I just replaced my motor "valve dropped" It was running perfect until one morning My Engine light turn on, I scanned It with my programmer got the code It was a Evap Small leak they said could be gas cap It was'nt I was the vacuum line header made a small hole check your hoses and wiring.
Old 04-03-2010, 12:27 PM
04ram4X4's Avatar
Color: Blue
It was the gas cap
