Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > 5.9L V8 Specific Topics
Old 03-29-2010, 09:59 AM
Ramrob Ramrob is offline
Vehicle: 1999 Dodge Ram 1500 5.9L
Rep:75
Ramrob will become famous soon enough
Default Header bolts install
I had bought some headers 2 yrs ago and had a hard time getting them tight. I did the best I could with the hex bolts and was burning out gaskets. Took them off and sold them. Just got a new pair of stainless ones and want to know what's the best way to get these one. I know of one person that matched threads with some allen head bolts. He said they were easier to tighten?
Old 03-29-2010, 10:29 AM
Rep:1909
There are three common causes for burning out gaskets. Cheap gaskets, bolts that back out and warped flanges. If you using good headers and gaskets, I'd recommend using a locking bolt such as Stage 8.
Old 03-29-2010, 10:30 PM
The best thing you can do is once you get them up to temperature go back and snug them up again . You will be surprised how much more you can tighten them . Thats what I have always done and never had a header leak .
Old 03-29-2010, 10:32 PM
Use good gaskets, with a set of Stage 8 fasteners, and you won't have leaks or burned gaskets. Once you install the fasteners, give them 200 - 300 miles, pull the clips, check the torque on the fasteners and re-clip them so they don't back out.
Old 03-30-2010, 08:42 PM
Rep:75
thanks, will get them on soon
