Old 03-31-2010, 08:43 PM
chefred112's Avatar
Vehicle: 2005 Dodge Ram
Rep:656
im not sure if those are the b.v. heads you specified but nonetheless those heads should increase power quite abit..
Old 03-31-2010, 11:33 PM
moparmike07's Avatar
moparmike07 moparmike07 is offline
Vehicle: 07 dodge ram 1500
Trim Level: st
Color: silver
Rep:68
moparmike07 will become famous soon enough
ya because ported heads should make a difference in power good difference right? how hard is it to put in? do you think that the valve body is a good investment? i mean there only 325 dollars. also how hard that to be install? like if i put gears converter pulleys and tq converter how much pain to put them in? thanks its alot question but thanks again
2007 dodge ram 1500 quad cab 4x4 5 percent tint all around 35 percent windshield, ported tb, diablo sport, arh headers, magnaflow dual exhaust, magnaflow y pipe, krc210x cam,nitrous,CNC ported head. 4.56 motive
Old 04-01-2010, 12:43 AM
chefred112's Avatar
Rep:656
no problem Mike...that's what forums are all about..I knew nothing about diggin into vehicles til I got my truck..just oil an coolant changes an brakes.. after i got my truck i was all over forums seein what others have done to their trucks and readin how to's.. now I've learned how to rip into our hemi's and have done over 25 cam/head installs. Valve body's aren't too hard to change..but can be messy if you don't watch what you're doin, tq vertors are time consuming to change, especially if you don't have the right tools (tranny jack is a must)... i haven't done gears cuz I don't know about the shimming stuff and adjustments needed to do it right. pulleys are easy to do...
in terms of how hard or easy it is to change stuff... the easiest to change are any of the pulleys, followed by the vb, then tq vertor, then heads...
Old 04-01-2010, 01:10 AM
Trim Level: st
Color: silver
Rep:68
ok so you think that they are a wise investment??
Old 04-01-2010, 01:14 AM
Trim Level: st
Color: silver
Rep:68
also what is the difference between the 5.7L Inertia Performance Cylinder Heads and the SharaDon Performance SP-1 5.7 Hemi Ported Cylinder Heads the interia are more. i cant see the spec
also are you on spray??
Old 04-01-2010, 01:26 AM
chefred112's Avatar
Rep:656
no spray here..I'd potentially be pushin 11's with spray...I love how she perfoms now on a daily basis (especially with over 180k miles). I love rollin up at almost every stoplight knowin i could take alot of different cars an trucks... i'm not sure of the difference between the 2 heads but I do know they both perform very well.. yes, all good investments, the only experience i don't have is with the shradon vb but I do know guys that have it and love it... altho 1 of them jacked up his tranny but we're not sure if the vb was the cause...
Old 04-01-2010, 01:58 AM
Trim Level: st
Color: silver
Rep:68
does Inertia make valve body? OK so its just for smoother shifting i mean for 325 dollars i buy it put to the side. but the most power s from the ported heads what the difference is there like a huge difference because i reading them and they don't say really what they upgrade i was looking at 5.7L PREMIUM Big Valve Cylinder Heads but dam 2 grand ehh. finally i bought krc210x cams. can i let them sit downstairs for a while till i get more money because i want to put all parts in at once. its not bad like it wont mess anything up leave them for like a month or two or more?
Old 04-01-2010, 03:32 AM
chefred112's Avatar
Rep:656
no..it's not for smoother shifting.. it'll shift so hard you'd think you broke something..hehe..as for cams...I let my 6.1 cam sit for almost a year before i put it in..just make sure you keep it lubed while stored..
Old 04-01-2010, 12:01 PM
Trim Level: st
Color: silver
Rep:68
hmm ok anything else you can think of ??
Old 04-01-2010, 05:08 PM
MotorCityRam's Avatar
MotorCityRam MotorCityRam is offline
Vehicle: 2010 Ram QC 4x2
Color: Inferno Red
Rep:23
MotorCityRam is on a distinguished road
Biggest gain for the money will be the gear change. That's almost always a guarantee. Next on these motors (based on the specs...I'm an old sbf guy) is going to be a cam. Headers too before heads. These stock heads flow as good or better than the aftermarket race stuff I had for sbf's. I'd be willing to bet there's more to pick up w/ a decent cam (flycut the pistons for clearance if you have to or refresh the short block and replace the pistons) and a tune than paying someone for ported stock heads. Do a simple tootsie roll cleanup on the heads.
Just an opinion based on years of wrenching on stock iron heads camming those stock heads, porting said heads, recamming the combo, new aftermarket heads, recamming THAT combo, blah blah blah.
Freddie...argueably you're not makin' a hell of a lot more power than that cammed combo I listed in the Hot Rod article and that was stock heads. I think you may be doin' it w/ a bit less cam though too.
Sean M
2010 Quad Cap Sport 4x2 / Inferno Red / HEMI / 3.92s / leather / Truxedo Truxsport tonneau
