Old 03-30-2010, 11:21 PM
mxd909's Avatar
mxd909 mxd909 is offline
Vehicle: 2005 Dodge Ram 1500
mxd909 is on a distinguished road
Default '05 Hemi Truck stalls.
I have a 2005 ram 1500 5.7L Hemi, with the 545RFE. About two weeks ago I did a trany fluid exchange, and replaced both the filters. I did this after having the delayed engagement after start up. There was a TSB on it and it said to replace the filters. I put them in properly and sealed it back up. After this my truck stalls at every stop light or stop sign. I can't figure it out. It does it on the freeway sometimes also, slowing down for traffic. I can fell the truck surge, is a way i can put it, then stalls. Any ideas. I used The right ATF+4, and its full.
Old 03-30-2010, 11:26 PM
Any codes ?
Old 03-30-2010, 11:34 PM
clintho1 clintho1 is offline
Gender: Not Specified
Vehicle: 03' 5.9 1500
clintho1 is on a distinguished road
if it happens enough you should get a check engen light . if you do then turn the ignition on and off 3 times and then off real fast without starting the truck the odomater will spit out a code ... tell auto zone and they'll tell you what prob is
Old 03-30-2010, 11:35 PM
When was the last time the throttle body was cleaned ? May want to make sure the plate and bore are clean .
Old 03-31-2010, 12:31 AM
mxd909's Avatar
Ok. No codes. It has done this over 100 times now. I am changing the plugs and wires tomorrow I will check the throttle plate and bore then. I hooked a scan tool and no help.
Old 03-31-2010, 01:06 AM
droshemiram's Avatar
droshemiram droshemiram is offline
Vehicle: 03 dodge ram HEMI
Color: atlantic blue
Rep:89
droshemiram will become famous soon enough
did you check the fluid when the trans is warm and in park or in nuetral some people forget to do that.goodluck on finding out the problem you can also call the dealer see If their is a recall on your situation?? you never know.
Old 04-03-2010, 11:50 PM
kgmunro kgmunro is offline
Rep:14
kgmunro is on a distinguished road
Default sounds like convertor
we had some come in our shop with this issue...the convertor was not coming out of lockup and causing a lugging and stalling problem.
Old 04-16-2010, 12:36 AM
mxd909's Avatar
Well guys. Cleaned the throttle plate. no codes. took it to the dealer and same sh!t, This is driving me nuts.
Old 04-16-2010, 12:37 AM
mxd909's Avatar
What was the fix?
