Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > V10 Specific Topics
Old 03-31-2010, 06:17 AM
daviehill80 daviehill80 is offline
daviehill80 is on a distinguished road
Default help not firing
ive got a 1996 ram3500 V10 put a new timing chain now not firing reading no codes also new cam sensor
Old 03-31-2010, 09:01 AM
Rep:1884
Getting an injector pulse? Could also be a crank sensor, ASD relay or several other things.
Old 03-31-2010, 09:05 AM
iRESQu iRESQu is offline
Rep:2217
I see you're new to the Forumz, so welcome. I wish you the best and I see you've got our best, knowledgable member already chiming in, so best of luck.
Take care and see you around the Z!
Old 03-31-2010, 09:29 AM
ok here is my deal i bought the truck from an electrican pulled it home he finally came by and help[ me get it started under the hood in the main relay box he had bypassed the ASD relay with a jumper wire blown the big square fuse that says engine but i replaced it and it has not blown any more I drove it about a week then one day drove up to the store and got 20$ gas drove back home shut it off next time i crunk it it was missing bad bad had no power in gear month later i started fooling with it again it never did start but somehow the timing chain broke replaced it and the cam sensor now no spark i willing to bet my problem has something to do with the ASD i would say that yhe injectors are pulsing i smell gas when trying to start it i have read though ALLDATA from one end to the other twice im stumped
Old 03-31-2010, 10:55 AM
Rep:1884
No offense but it sounds to me like you're guessing and should get someone that's qualified to diagnose it or you'll likely wind up spending more in throwing random parts at it than you will to have the diag done.
