Why is my 98 ram 1500 still cutting out??? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > 5.2L V8 Specific Topics
Old 03-31-2010, 07:16 PM
98Ram1500 98Ram1500 is offline
98Ram1500 is on a distinguished road
Thumbs down Why is my 98 ram 1500 still cutting out???
I got this truck and was told it had a new crank sensor put in a few months ago and that it needed a new fuel pump. The tuck cuts out on me some days and others it runs fine. I put a lot of parts on this truck and it has not change a thing. here is a list of all the parts and what my truck does...
fuel pump (entire module with pressure reg)
coil
cap and rotor
plugs and wires
cleaned the injectors
oil and filter
air filter
down stream o2 sensor
ABS speed sensor ( speedometer still works whenever it wants to)
speed sensor on the bottom of tranny
AND IT STILL CUTS OUT!!!!!
The truck almost acts like its vapor locking or something. It will do it when I pass someone or give lots of throttle or do it when I am going like 15mph down a hill. There is a clicking or (sparking) soud made when the engine cuts out. I have no more ideas and any help is much appriciated. I have heard it might be a throttle sesor or map sensor or maybe a bad ground or voltage reg. PLEASE HELP!!!!!!!!!!!!!!!!!!!!
Old 03-31-2010, 07:21 PM
Rep:1625
Welcome to the forum! Glad to have you here! Hopefully someone can lead you in the right direction.
Old 03-31-2010, 08:10 PM
Ram98's Avatar
Ram98 Ram98 is offline
Vehicle: '98 Ram 1500 , 2004 Rumble Bee
Trim Level: Sport,Rumble Bee
Color: Blue, Yellow
Rep:28
Ram98 is on a distinguished road
Have you tryed the fuel filter?
98 Ram 1500 Sport 4x4 5.9L
2004 Ram 1500 4x4 Rumble Bee
Old 04-03-2010, 08:02 AM
well the filter is in the pump module in the tank and al of its brand new.
Old 04-03-2010, 08:13 AM
Resident Technician
Rep:1915
Time to stop throwing parts at it and get a proper diagnosis. The money you've already spent would have covered a diag fee.
Old 04-03-2010, 09:15 PM
I have taken the truck to the local Dodge dealership three times and they are the ones that told me to do the fuel pump and the o2 sensor and they were wrong. Ipaid them just to look at it and diagnose it three times for $86.00 each time and i'm never going back. I am an ok mechanic and did the work myself but nothing seems to be doing the trick any advice would be great!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old 04-04-2010, 08:25 PM
Ram98's Avatar
Color: Blue, Yellow
Rep:28
I haven't turned wrenches since the 70's but kind of sounds like a problem Caddy's used to have. They had double walled exhaust pipes and the inner wall would collapse causing a problem similar to yours. Have you checked the Cat? This was a hard problem to diagnose unless you'ed come across before. I would check the Cat first before buying one though.
Old 04-04-2010, 09:38 PM
Michelle's Avatar
Michelle Michelle is offline
Vehicle: 2001 Dodge Ram 1500
Trim Level: Laramie SLT
Color: silver
Rep:12
Michelle is on a distinguished road
Mine was doing what sounds like the same thing and I ended up having to replace the PCM after many other parts first. After I replaced it my truck runs great!!
~Dodge Damsel~
Old 04-04-2010, 09:46 PM
aolslayer's Avatar
aolslayer aolslayer is offline
Vehicle: 1998 Durango SLT 4x4 Green
Trim Level: custom
Color: Green
aolslayer is on a distinguished road
Send a message via Yahoo to aolslayer
i have a 97 ram 1500 i have the same problem i was told to replace the throttle position sensor i think that is what your problem may be too watch you mite notice your rpms droping below 1000 befor it cuts
98 Durango SLT 4x4
Old 04-04-2010, 10:50 PM
Is that the computer? (PCM) How much do they run off hand??? Is it worth buying like 2 or 3 of them used from a junker or just stay with a new one?
