Old 04-04-2010, 10:52 PM
98Ram1500 98Ram1500 is offline
98Ram1500 is on a distinguished road
Originally Posted by aolslayer View Post
i have a 97 ram 1500 i have the same problem i was told to replace the throttle position sensor i think that is what your problem may be too watch you mite notice your rpms droping below 1000 befor it cuts
well it doesnt do it at an idle just when i go to pass a car or go up hill usually but sometimes its just driving normal down the road. Crank sensor???
Old 04-04-2010, 10:55 PM
it doesnt ever cut at an idle just when driving. Could this be a crank sensor too??
Old 04-05-2010, 12:01 AM
deanthecrabman's Avatar
deanthecrabman deanthecrabman is offline
Vehicle: 2001 Ram 1500 Quad 4WD 5.9
Trim Level: Quad cab
Color: Garnet red
Rep:202
deanthecrabman has a spectacular aura aboutdeanthecrabman has a spectacular aura aboutdeanthecrabman has a spectacular aura about
I agree with Remerson, you need to find somebody else to check it out, or let the dealer fix what they find. If what they do doesn't fix the problem, it's on them. I like to fix things myself too, but sometimes enough is enough. My time is worth something, too.
Old 04-05-2010, 12:11 AM
TerryXn9's Avatar
TerryXn9 TerryXn9 is offline
Vehicle: 2010 RAM
Trim Level: Crew Cab Sport
Rep:31
TerryXn9 is on a distinguished road
Hope you get it fixed!!!! Sounds like you about at your wits end.
2010 Crew Cab Sport! With a HEMI
Old 04-05-2010, 12:36 PM
Well the last time I took the truck in to the dealer strictly for the "cutting out" and they said nothing was wrong with it. The check engine light remains on and they say that there is no problems. I havent had the converter looked at yet I put a new neg. cable on today. That changed nothing either. I have been told cam sensor crank sesor and throttle pos sensor also been told it may be the PCM. The dealer has monkey emplyees so I have to figure this out myself unfortunately!!
Old 04-05-2010, 04:52 PM
aolslayer's Avatar
aolslayer aolslayer is offline
Vehicle: 1998 Durango SLT 4x4 Green
Trim Level: custom
Color: Green
aolslayer is on a distinguished road
Send a message via Yahoo to aolslayer
Originally Posted by 98Ram1500 View Post
Is that the computer? (PCM) How much do they run off hand??? Is it worth buying like 2 or 3 of them used from a junker or just stay with a new one?
no not computer its on the outside of the throttle body if u look at it from the front of your truck its the plug of wires going in to the throttel body on the right side of it it a sensor that plugs in the side of your throttle body
98 Durango SLT 4x4
Old 04-05-2010, 04:54 PM
aolslayer's Avatar
Trim Level: custom
Color: Green
mine dose that to just not as frequently as yours but i cost me 60 for the sensor at auto zone
98 Durango SLT 4x4
Old 04-06-2010, 01:22 AM
Incognito's Avatar
Incognito Incognito is offline
Vehicle: 2003 Dodge Ram 1500 Crew Cab
Trim Level: 5.7L Hemi 4x4
Color: Graphite Gray
Rep:72
Incognito will become famous soon enough
I have taken the truck to the local Dodge dealership three times and they are the ones that told me to do the fuel pump and the o2 sensor and they were wrong. Ipaid them just to look at it and diagnose it three times for $86.00 each time and i'm never going back. I am an ok mechanic and did the work myself but nothing seems to be doing the trick any advice would be great!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
S**t, what a bunch of hack techs they have at that dealership. I'd go to a different Chrysler dealership and file a complaint with the one you went to before. I hope things turn out.
