Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > Dodge Ram Detailing and General Maintenance Forum > Interior Cleaning and Maintenance!
Interior Cleaning and Maintenance! Keeping the inside clean!
Old 03-31-2010, 09:46 PM
jayhkr's Avatar
jayhkr jayhkr is offline
Vehicle: 2006 Dodge Ram SLT 4x4
Color: Atlantic Pearl Blue Metallic
Rep:75
jayhkr will become famous soon enough
Send a message via ICQ to jayhkr
Default Rug Doctor on Upholstery
Ok, I decided to put a thread here showing what I was able to achieve using my rug doctor machine with hand tool. If you're not aware of what a rug doctor is, it's basically rug cleaning machine that can be rented from most hardware and grocery stores. I decided to buy mine as I got to lazy in going back and forth to the store renting them. My equipment was basic:
- Rug Doctor w/Hand Tool
- Shop Vac or other vaccum
- 1/4 cup Simple Green mixed with 1/2 gallon water
- Upholstery brush bought at Wally World
My proceedure was as follows:
1) Vaccumed carpet to get big loose debris up
2) Used upholstery brush to dry scrub carpet to get up as much dirt and debris as possible.
3) Re-vaccumed.
4) Sprayed solution from Rug Doctor's hand tool LIBERALLY over carpet. I made 2 passes over the area I was cleaning at about 2-3" above the carpet. The areas was wet, but NOT saturated.
5) Used upholstery brush to scrub the area going both with and against the "grain" of the carpet.
6) Used the hand tool on the rug doctor to suck up as much solution as possible, again going with and against the "grain" of the carpet.
7) Repeated area if needed.
8) After everything was dry (which wasn't long) I vaccumed the carpet one last time.
Here are the results of the floor mats, both before and after! I was amazed!
BEFORE:
AFTER:
As you can see, the simple green solution worked great! Considering you can buy a jug of this (which makes up to 15 gallons worth) for under $5.00 and can be used on so many areas of our truck, how can you go wrong! Anyway, the past two days where spent doing the entire truck, both inside and out. Man do I feel tired too! Enjoy!
Old 03-31-2010, 09:47 PM
Rep:1625
Nice job, they look great!! Take a break, you deserve it!!
Thanks for the pics!
Old 03-31-2010, 09:56 PM
jayhkr's Avatar
Rep:75
Already got beer in hand. Thanks. The rest of the interior was pretty bad, had some nasty stains on it from last summer so now it ALMOST looks like it when I picked it up from the dealership last year.
Old 03-31-2010, 09:58 PM
Rep:1625
I've got a pretty nice coffee stain of my passenger side (got it from the dealership that way) I'll have to look into this treatment, thanks.
Old 03-31-2010, 10:08 PM
I push the skinny pedal
Rep:3277
Did a great job, looks nice and clean just by looking at the mats, can only imagine how different the interior is.
Kurtis
Old 03-31-2010, 10:41 PM
dodgeman70592's Avatar
Vehicle: 2008 Dodge Ram
Trim Level: Custom
Rep:1648
I see a new purchase in my future...
Old 04-02-2010, 11:18 AM
Barnyard's Avatar
Barnyard Barnyard is offline
Vehicle: 2011 Ram 1500
Rep:209
So you just used Simple Green (not the solution 'made' for the carpet cleaner, correct? I may have to try that on the house next time!
Old 04-02-2010, 04:01 PM
ScatPak07's Avatar
Rep:970
Wow those came out really good! Thats a good thing to do at the same time you are planning on cleaning the house carpets. Rent it for the day and clean everything you own hahaa
Old 04-03-2010, 07:48 AM
jayhkr's Avatar
Rep:75
Barnyard - yep just a 1:30 solution of simple green to water ratio. Go to ANY store pretty much and pick up the jug size container that says it'll make up to 15 gallons. For the truck I only used 1/2 gallon. This Monday or Tuesday I may try it on our carpets to see how it comes out. It's a lot better than the overly priced chemical stuff. I have a new grandbaby that is living with us, so the less chemicals the better. Simple Green is a biodegradable solution, so it's a bit safer than the Rug Doctor stuff. Thank you to everyone for the comments!
Old 04-07-2010, 11:38 PM
nlosinski nlosinski is offline
Vehicle: 2003 Dodge Ram 1500
Color: Gray
nlosinski is on a distinguished road
at where i work... best way to clean the floor mates is actually with a presser washer.. give it a try.. soon as u start blasting it with a presser washer.. you will see right away what the rug doctor left out
presser washing ur carpet will take all of the fine dirt, sand and crap that sits at the bottom... it wont hurt them, just needs to be hung up to dry after
