RUST issue with 2010 4x4 Ram Big Horn...anyone else having this issue - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 04-01-2010, 10:45 AM
SupermanWV SupermanWV is offline
Vehicle: 2013 RAM 1500 4x4
Trim Level: Express Quad Cab
Color: Copperhead Pearle
SupermanWV is on a distinguished road
Default RUST issue with 2010 4x4 Ram Big Horn...anyone else having this issue
I have a 2010 4x4 Ram Big Horn, and I've only had it a couple weeks now. I am noticing after a rain, or after washing the wheels, that rust is coming out through the little chrome ram head hubs that are in the 20 inch rims.
I took the rim off and notice that the wheel hub is rusting around where the axle nut is. For the most part the metal in that area is like machined and very smoot and shinny, but it is starting to rust like any other rotor does. But for whatever reason, the water that gets in there doesn't drain out and it eventually spins out while driving and gets rusty water all over my wheel.
What can I do to prevent this? It happens on all 4 wheels. (4 Wheel disc brakes).
If anyone else is having this issue please tell me what you have done to fix it.
Thanks
Clark (SupermanWV)
Old 04-01-2010, 10:49 AM
Resident Technician
Rep:1915
I'm guessing you have the chrome clad wheels. My suggestion is to get rid of them.
Old 04-01-2010, 01:59 PM
No I have the 20 inch aluminum or alloy wheels. They are painted a metalic silver and have a plastic chrome Rams head cap in the center of the wheel. They are not the Chrome-Clad. The part that is rusting is where the rotor fits over the lug bolts and axle, and the axle nut actually shows. The machined/zinced part of the rotor is what is rusting. In the past that axle nut and stuff had a cap over it. It doesn't with the Dodge. But the water gets in and sits on that lip and rusts. Then when the tire moves it flings the rusty water out around the cap that is in the center of the wheel.
Clark (SupermanWV)
Old 04-01-2010, 02:09 PM
Rep:2929
I have read several posts about the rust thing, everyone else seems to let the dealership know about it when the went for service or another problem. The dealerships have either fixed it or replaced the wheels. Some people have gone back with the same problem a second time
If you have the metal bumpers, check them too
Old 04-01-2010, 02:11 PM
It's not the rim that is rusting. The hub area is rusting and the rusty water from that runs out the cap in the wheel and gets all over the wheel.
The wheels are alloy and will not rust.
Clark (SupermanWV)
Old 04-01-2010, 03:32 PM
Resident Technician
Rep:1915
I've not personally seen this problem as of yet. Sealing up the center caps isn't an option, so I would recommend removing as much rust as possible from the hub and spraying it with a coat of Rustoleum and then reinstalling the wheels.
Old 04-01-2010, 03:51 PM
2500 HD 2500 HD is offline
Vehicle: 2010 2500 Ram HD mega cab
Trim Level: laramie
Color: bright silver
2500 HD is on a distinguished road
+1
Old 04-02-2010, 03:45 AM
bigdadsram bigdadsram is offline
Vehicle: 2010 dodge ram quad cab
Rep:31
bigdadsram is on a distinguished road
My wheels did the same thing. It looks like crap. For some reason these trucks rust very bad, very fast. I know they have had some issues with some of there vendor using poor quality metals and processes and chrysler has been moving to new vendors to try to get a handle on the rust issues.
Old 04-02-2010, 07:38 AM
cartert1975 cartert1975 is offline
Vehicle: 2010 Ram 1500
Color: Inferno Red
Rep:17
cartert1975 is on a distinguished road
I had the rusty hubs issue with my 2009. Didnt bother having the dealership look at it because I traded the truck after 6 months.
Old 04-02-2010, 08:28 AM
+ + 2
